Old 02-08-2014, 12:44 PM   #1
Hioridge
Default Block Heater for Model A
Does anyone know of a head-bolt or other type of block heater for a Model A?
I need to start my A which has been sitting in my cold barn in Maine all this winter.
Hioridge is offline   Reply With Quote
Old 02-08-2014, 12:53 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Block Heater for Model A
A magnetic block heater should warm it enough.
Old 02-08-2014, 12:58 PM   #3
Kurt in NJ
Kurt in NJ's Avatar
Perhaps you can get an inline hose one and put in the lower hose near the block
Mine started without doing anything after 3 days on cold for here nights and 25 degree days ---with a 10 year old battery made from 1/2 of a 12 volt battery
drain the oil, warm it up,put it back in, have a fully charged warm battery
take one of those electric hot air heaters and let it blow on the engine for a while
If you start it run it until the oil is hot to evaporate condensation ----otherwise it is best to leave it unstarted till you are ready to drive,
Old 02-08-2014, 10:35 PM   #4
tbirdtbird
get the small size torpedo heater (runs on kero) at Lowe's etc , open the hood, and aim it in there for 30 min. It will be warm as toast. Be sure battery is up as has been stated
'31 180A
tbirdtbird is offline   Reply With Quote
Old 02-09-2014, 10:53 AM   #5
Smurkey
Smurkey's Avatar
You could probably squeeze a lower radiator hose heater in there.
http://ecx.images-amazon.com/images/I/51Ws3l8M2eL.jpg
Steve
Smurkey is offline   Reply With Quote
