I picked this little guy up at Turlock today for $15, pretty interesting home-made manifold. I've never done any kind of speedy things to a model a, but I couldn't pass this up and might someday use it. Any opinions on this thing from what you can see in the pictures? I was told it might accept a chevy 1-barrel, I have no idea about downdraft carburetors so maybe some folks could school me on it, and if this thing would work fine or if it's just a wall hanger/conversation piece. The flange is definitely an odd shape. I definitely like things like this on cars though, farm ingenuity is more exciting to me than high-dollar "buy-and-bolt" things (no offense, if I had a massive wallet I wouldn't mind buying all kinds of aluminum this and that.)
putting a Rochester carburetor ( from a chevy) or a Carter ( from a mopar car) was not an uncommon experiment in the 50's. They have different base sizes, so you'll have to try them out to determine which works. You might need a fuel pump to get them to work.
I looked at a bunch of carbs today but got overwhelmed with all of the different ones, especially the prices varying so much! What sort of models are common, which are better, and what kind of prices should I expect? Is this a good route to go, or should I try to go more towards the stromburg route? I know that's probably a lot of vague questions, but I am not expecting very precise answers
You probably want to stick to a hand choke to avoid the hassle of hooking up an automatic choke so a carb from a '40's or 50's car or pickup into the '60's will work. In addition to Carter and Rochester there are Holley and Ford (Autolite) and Stromberg one barrels. Most came on engines with about the same displacement as a Model A so jetting should be close enough. Big thing is to get matching bolt pattern and then look at how easy the throttle linkage would be to adapt.
#5 | |
![]() Quote:
throttle linkage attachment/pivot point
looks like a single barrel holley off a falcon or inline 6 ford/edsel may fit it i can measure mine if you want
throat is 1-1/2" and studs center to center are 2-5/8" for anyone who wants to measure their different carb flanges. thanks!
I have made several single and dual manifolds for model A's and used the Holley 847 single throat carb from early Ford 6 engines. There are several model numbers in that series that will work also.
They are reasonably priced. |
#12 | |
![]() Quote:
#13 |
One popular carb was a small glass bowled Holley. Some guys ran Jeep carbs.
