Old 01-12-2014, 12:00 AM   #1
Bob from Northport
Bob from Northport's Avatar
Default Model A drivability question
Does anyone know of a way that a Model A can be set up for handicap usage, i.e. poor leg strength??
Thanks!!
Bob
Bob from Northport
Northport, Michigan
Bob from Northport is offline   Reply With Quote
Old 01-12-2014, 12:13 AM   #2
Mike V. Florida
Mike V. Florida's Avatar
Default Re: Model A drivability question
Easy, Automatic tranny.
http://www.transmissionadapters.com/Model%20A.htm
Old 01-12-2014, 12:41 AM   #3
Mike V. Florida
Originally Posted by BILL WILLIAMSON View Post
"EASY"???????????????????????? AND, whut about STOPPIN'?????????????????????? AND, whut about jist climin' up into the car????????????????" AND, jist tryin' to git out uf the car????????????????? (Ol' Bill knows how HARD it is!) Buster T.
He said poor leg strength, not no leg strength.
If he can't even get into/out of the car, then maybe he should not be driving it.
Old 01-12-2014, 01:07 AM   #4
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Mike, Dog here, I KNOW he sed "POOR LEG STRENGHTH", I kin READ! You have to be "ALMOST" an "ATHLETE" to drive a Model A SAFELY! Thu KEY wurd is SAFELY!! Buster T.
"THE ASSISTANT GURU OF STUFF"
Old 01-12-2014, 03:17 AM   #5
dave in australia
Yep, got to stop em as well.
dave in australia is offline   Reply With Quote
Old 01-12-2014, 04:06 AM   #6
Mike V. Florida
Properly restored brakes will take care of that.
Old 01-12-2014, 08:59 AM   #7
dave in australia
I was going along the line that if you have poor leg strength and have trouble operating a properly restored clutch system, which should be no heavier than a properly restored brake system, then the brakes will be difficult to operate as well.
There was a chap here in Victoria that fitted an auto trans to his A. He said he had trouble finding a torque converter that would give enough drive at the lower end of the A's RPM range. He felt that it needed to be revved a lot during takeoff to gain momentum. He said that a std speed converter acted like a high stall in a modern car. His words, not mine. All my A's are std manuals.
If the poor person is an amputee, then that's a different story.
Old 01-12-2014, 11:16 AM   #8
Patrick L.
Patrick L.'s Avatar
Maybe a V8 clutch and a hydraulic brake system with a booster.
Old 01-12-2014, 11:39 AM   #9
BILL WILLIAMSON
In 1963, I added a small Bendix Hydro-Vac brake booster to the hydraulic clutch system on a Jaguar XKE, for a guy that had a weak left leg. Those clutches were VERY STIFF & even had a short clutch pedal, that made it even more difficult to push!
Bill W.
Old 01-12-2014, 12:25 PM   #10
Tom Wesenberg
Tom Wesenberg's Avatar
Use the clutch from a 1949 Chevy pickup. I'm sure it fits a lot of GM cars, but my friend's 49 pickup had the nicest softest clutch I've driven.
No need for hydraulic brakes, you can add a vacuum booster to mechanical brakes also.
Old 01-12-2014, 12:39 PM   #11
modelAtony
modelAtony's Avatar
Thanks!!
Bob
Restorer magazine may/june 2012. Page 12 titled CHALLENGES & obstacles by George Pope, Visalia, CA . A friend of author has a 29 Tudor set up for rear entrance, hydraulic chair lift and has been fitted for his wheel chair to replace seat. and has controls for him to drive . I have also seen articles with other like A's set up for handi cap . Have fun modelAtony tony white Lafayette, LA
modelAtony is offline   Reply With Quote
Old 01-12-2014, 12:44 PM   #12
Benson
Here are adapters for GM transmissions like 350 THM. Might fit Holden and other GM derivatives.
Torque converter mods are readily available for these transmissions.
Although the THM 350 that I had (2.54 rearend) worked fine with the 267 V8 which ran at 2200 RPM at 60 MPH.
This engine speed is close to Model As.
URL is here: http://www.transmissionadapters.com/Model%20A.htm
Transmission Adapters
Home
About Us & Magazine Articles
Customer Comments
Gallery
Kit Pricing
Product Development
Transmissions
Other Products
Parts Wanted
Installation Instructions
Machining Services
Links
My Rides
Good Used Stuff
Announces our newest addition to the adapter family.
Model 'A' & Model 'B' to Chevrolet Automatic Transmissions
This kit will allow you to bolt up any of the Chevrolet automatic transmissions (700R4, 350 TH, 400 TH, 2004R, Powerglide, etc.) to the Model 'A' and Model 'B' motors.
Kit Contents:
Adapter Plate
Crank Adapter
Flex Plate
Torque Converter Drive Plate
Starter Adapter Plate
Mini High Torque Starter*
Bolt Kit
*This starter will only work with our kit.
Kit Retails for $1195.00 USD
13603 Johnson Street NE Ham Lake, MN 55304
763-767-4480 Voice 763-862-5581 Fax
Old 01-12-2014, 01:20 PM   #13
Patrick L.
Patrick L.'s Avatar
Originally Posted by bill williamson View Post
in 1963, i added a small bendix hydro-vac brake booster to the hydraulic clutch system on a jaguar xke, for a guy that had a weak left leg. Those clutches were very stiff & even had a short clutch pedal, that made it even more difficult to push!
bill w.
lol !
Old 01-12-2014, 01:21 PM   #14
Patrick L.
Patrick L.'s Avatar
Thanks!!
Bob
Are you throughly confused yet ?
Old 01-12-2014, 01:47 PM   #15
Brother Hesekiel
Brother Hesekiel's Avatar
And then there's the Shay Roadster: Ford Pinto inline-4 with Ford C4 automatic transmission. Don't discard that idea right away; I have driven one in 2006 and it was fun!
Brother Hesekiel is offline   Reply With Quote
Old 01-12-2014, 02:57 PM   #16
BILL WILLIAMSON
lol !
And WHY was that FUNNY??-------Bill W.
Old 01-12-2014, 03:33 PM   #17
Pete
Thanks!!
Bob
Any car can be modified to accommodate many different handicaps.
I have seen model A's with hand controls for non functional legs.
The methods need to be tailored to the individual.
I have even seen a 34 Ford driven almost daily by a guy with NO ARMS.
As I recall, the guy said he had a heated steering wheel rim so his feet didn't get cold in the winter.
Old 01-12-2014, 04:29 PM   #18
Kevin in NJ
How weak?
You can reduce clutch pressure with a V8 pressure plate. The ones with the counter balance. Some are without the counter weights and have the same pedal pressure.
A very carefully gone through and restored set of brakes can stop the car like manual hydraulics. BUT, manual hydraulic brakes still take way more effort then modern brakes. I believe there were some truck vacuum assist systems that could be adapted for mechanical brakes. Ask Kurt in NJ (my brother) as believe he was the one telling me about them.
So how much pressure can he apply and figure from there. Can he stop a 4 wheel non-assisted drum brake car?
