Old 12-20-2013, 01:53 AM   #1
insomniacshotrods
insomniacshotrods's Avatar
Default Model A engine timing for a new guy
Having never done this before i took my good running engine and thought id learn how to time it, how hard can it be? Pulled #1 spark plug ,put a piece of masking tape lightly across hole ,and got my timing pin out and turned around . After fighting the hand crank and trying to feel the timing pin drop in for over an hour, I thought there has got to be a better way. I cut the shaft off the Taiwan hand crank and found a 17mm socket fit perfect so i welded that on, but still needed to use an extension to clear light bar. Made up a light with clips and got the nu rex wrench,not necessary but I already had it, and most important to me was the ez set timing tool. http://www.mikes-afordable.com/product/T6254.html Made it a heck of alot easier. Watch for the tape to blow up,then watch your rotor as it nears pointing to #1 piston,then just watch and see when pin move in. Attach your test light and do as follows http://youtu.be/mwirH7f0a9o .Also more good info http://fordbarn.com/forum/showthread.php?t=125157. My car now has that distinctive Model A idle sound with both levers up and runs great. Many thanks to the people on here who helped me and my model a buddy Dan. I hope this can help someone new to the hobby like myself.
Enjoy life , it has an expiration date.
insomniacshotrods is offline   Reply With Quote
Old 12-20-2013, 04:24 AM   #2
johnbuckley
johnbuckley's Avatar
Default Re: Model A engine timing for a new guy
On an unknown engine (of any make) I find the simplest way of finding tdc is to slacken off the number 1 plug slightly and then a paint a bit of soapy water around it. Great fun watching the bubbles on compression inflate and deflate as it passes when turning it by hand and never fails.
Old 12-20-2013, 10:02 AM   #3
V4F
V4F's Avatar
get les Andrews red book
V4f
V4F is offline   Reply With Quote
Old 12-20-2013, 10:28 AM   #4
johnbuckley
WHAT???? you mean read the instructions!!??
Old 12-20-2013, 02:53 PM   #5
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
YEP! After ALL else FAILS, read the DANG INSTRUCTIONS!!!!! (My Dog reads EVERYTHING for me!)
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 12-20-2013, 10:19 PM   #6
whirnot
whirnot's Avatar
I think a lot of guys are expecting the pin to "drop" in and in truth the movement is way more subtle than expected. I also like that NU Rex timing tool. Makes it a breeze
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
1931 Coupe
2 Smith Motor Compressors
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
