Old 09-05-2013, 11:49 PM   #1
36tudordeluxe
36tudordeluxe's Avatar
Default '36 emergency brake lever problem
When I pull back on the emergency brake lever the pawl? doesn't engage in the teeth, seems like weak internal spring as I have to pull up on the thumb button on top of lever to get pawl to engage. Is this spring replaceable and a source?
36tudordeluxe is offline   Reply With Quote
Old 09-06-2013, 01:57 AM   #2
Bluebell
Default Re: '36 emergency brake lever problem
The knob is held on by a small pin. There is a short spring under the knob. Make sure it is not the pawl pivot at the bottom that is binding it up. If the control rod is bent it can bind.
It might all just need a clean and oil.
Good luck!
Bluebell is offline   Reply With Quote
Old 09-06-2013, 06:01 AM   #3
Terry,OH
Terry,OH's Avatar
They do get very dirty and rust covered, suggest you remove and clean and relube if the spring is bad I believe Brattons or Mac's has them.
Old 09-06-2013, 10:41 AM   #4
36tudordeluxe
Thanks for the info. guys. Will disassemble & see what I have.
