Old 08-09-2017, 03:15 PM   #1
dahrens1
Default Right side rear tail light mounting bracket question
Hello,
I recently decided to add a right side rear tail light on my 1931 4-dr standard Phaeton for safety reasons. Since I wanted the left to match the right I purchased a new left side bracket at the same time. Unfortunately the left side reproduction bracket does not come close to matching the original that was on the car. In the picture I have posted below you can see that the "tunnel" of the repro part on the left is much lower relative to the top bolt hole and this creates a problem because the center hole (in the fender) for the tail light wires will be 3/4 blocked. I would prefer not to move or enlarge this center hole. I am also not impressed with the quality of these repro parts. So my question to you all is this, does anyone sell a left side tail light bracket that is closer in design and quality to the original that also sells a matching right side bracket? I would prefer stainless steel but at this point gloss black would be just fine also.
Thanks for your help
Dave
dahrens1 is offline   Reply With Quote
