Old 08-20-2013, 02:08 PM   #1
AnthonyG
AnthonyG's Avatar
Default Think I need taller / wider tire / rim
Hey Guys, just got my '35 Tudor up and running with a higher HP Flat head than was stock, ( approx 160HP ). I have a stock 4:11 rear. Revving pretty high over 40MPH and it feels a little squirrely over 55MPH. Think I need taller and wider tire / wheel combo on rear? What Tire Wheel combo can I use to improve. Was thinking a pair of pickup wheels with larger tires?
Nomad
AnthonyG is offline   Reply With Quote
Old 08-20-2013, 02:44 PM   #2
Mart
Mart's Avatar
Default Re: Think I need taller / wider tire / rim
6.50, 7.00, 7.50's will all go on, each one looking more hot-roddy in turn. If it's just the revs that are a concern, 3.78's should be easy to find, 3.54's can be bought new, and if you want to spend money a Mitchell overdrive can be fitted, or a columbia rear.
You don't need the wider rims, but if you can get them easily, there's no harm in using them. It just depends how original you want it to look.
Mart.
Old 08-21-2013, 12:17 PM   #3
AnthonyG
AnthonyG's Avatar
Good stuff, Thx
Nomad
