Old 08-06-2013, 09:53 AM   #1
52fordv8
Default 52 ford eab engine ???
i recently picked up a runnign EAB engine from a 51-52 ford truck . and i will need to be converting it to be able to get it in my 52 customline so . i will be looking for a good used set of car pumps narrow belt . and i will be needing a 3 blade fan with narrow belt pulley . and i will be needing a 52 correct car oil pan as trucks and cars had differnt oil pans on suspention . car crank pulley.
52fordv8 is offline   Reply With Quote
Old 08-06-2013, 11:52 PM   #2
gearhead1952
gearhead1952's Avatar
Default Re: 52 ford eab engine ???
Also you will need a narrow generator pulley, narrow crank pulley and possibly different carb as the trucks use a different style clamp for the oil bath air cleaner. Will need a car starter plate to go with the oil pan. Not sure of the clutch linkage on the cars as to whether or not you need the stamped steel bellhousing.
gearhead1952 is offline   Reply With Quote
Old 08-07-2013, 08:28 AM   #3
52fordv8
this is whats i baught the engine to convert it to a car this is my 1952 ford customline i took down to the frame . i have the bell housing and new motor mounts and the radiator . and someone told me too that i can leave the flywheel on cause cars and trcuks had the same flywheel that id just have to change the clutch and oressure plate and throw bearing to a 9 1/2 inch.
Old 08-07-2013, 08:30 AM   #4
52fordv8
here is a pic of the engine compartment on my 52 ford customline that i want to convert the eab to fit
File Type: jpg 424790_10152313326915366_553649652_n.jpg (49.2 KB, 52 views)
Old 08-07-2013, 07:35 PM   #5
gearhead1952
Yes the flywheel will work. That bellhousing will work also just need the lower half plus car pan.
Old 08-07-2013, 08:22 PM   #6
52fordv8
ok ill start looking for the car parts. when i put a car oil pan on this eab it wont affect the oil pump will it is car and truck oil pump diff or same ???
Old 08-08-2013, 07:35 PM   #7
gearhead1952
I am pretty sure the oil pumps are the same.
Old 08-08-2013, 10:47 PM   #8
Ross F-1
Ross F-1's Avatar
An EAB is a car engine, not a truck engine, which would be an 8RT or 8BA. The EAB could have a truck oil pan or a car oil pan on it, each has its own oil pickup tube but the same pump. The flywheel has the same dimensions but if it was originally in a car, it may have a different pressure plate bolt pattern drilled into it.
My first question should have been, what makes you think it is an EAB? Is the block an EAB, the heads, or ??? Not unusual to find mixed up parts. Does the engine have narrow belts or wide belts?
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 08-09-2013, 12:48 PM   #9
52fordv8
the engine has round truck bell housing and has eab heads i know heads and pumps and all gets changed and etc over all these years but the way this thing looks it loks like its never been messed with . but who knows and it has wide belts and truck mount pumps . with the round hole . and it has a rear sump oil pan .
Old 08-09-2013, 12:52 PM   #10
52fordv8
here is the pic of the eab engine .
File Type: jpg 1157511_10153091508790366_441208776_n.jpg (74.5 KB, 42 views)
Old 08-09-2013, 12:55 PM   #11
52fordv8
i pulled this engine out of a 51-52 ford truck .
Old 08-09-2013, 02:01 PM   #12
Ross F-1
Ross F-1's Avatar
The oil pressure sender on the BH is a sign of car origins. Trucks had them on the Tee feeding the oil filter.
Old 08-09-2013, 02:03 PM   #13
52fordv8
so its a car engine been converted to go in a truck ????
Old 08-09-2013, 02:15 PM   #14
52fordv8
i know thats a bog thing with these engines almost everything is interchangable or etc u can make a car engine a truck engine and a truck engine a car engine lol i just know for it to be peiord correct for my 52 customline ill have to change the pumps to narrow belt where there have the slant mounting and ill have to put on a narrow pulley 3 blade fan and generator pulley got to be narrow and the crank pulley has to be narrow with the winged slots in it and i have to change the oil pan to a center sump pan as i call it where it has the indented round in the back of the pan to pass over the drag link and etc .
Old 08-09-2013, 02:32 PM   #15
Ross F-1
Ross F-1's Avatar
Unless you dig around inside (which you can when you change oil pans) there's no way of telling exactly what it is. If the crank is EAB, the block is EAB, then I'd say it's an EAB (which would be correct for your car). My truck has an EAB that was converted the other way, just as you describe, with a few exceptions.
One other clue to look at is the pointer on the timing cover for the ignition timing. Short = car, long = truck. With the truck pulley on there, I'd bet the end of the pointer is almost an inch from the pulley?
Old 08-09-2013, 04:30 PM   #16
52fordv8
here is the best pic of the pointer i can get .
File Type: jpg 1003342_10153095556110366_941298507_n.jpg (40.3 KB, 18 views)
Old 08-09-2013, 05:31 PM   #17
Barlea
A rebuilt engine could have come with heads but without pan or anything else that it would need to become a truck engine. Lots of trucks got 1CM or EAC 255 on the first or second rebuild. ..B.
Barlea is offline   Reply With Quote
Old 08-09-2013, 05:54 PM   #18
gearhead1952
The engine in my 52 and an 8ba just pulled from a 51 truck are just as pictured with the oil sending unit screwed into block. Also a 50 8ba pulled from an f3 same as pic.
