Old 08-05-2013, 10:14 PM   #1
oz1954
Exclamation how to remove quarter glass in 1929 model a tudor
I cracked the rr quarter glass in my 29 A tudor sedan.I have removed all parts and am down to the glass in the channels.I cannot get the glass out!The channels look to be riveted in,etc. but glass has been replaced before I got the car.Can anyone help me on this?
Thanks
oz1954 is offline   Reply With Quote
Old 08-05-2013, 10:19 PM   #2
700rpm
700rpm's Avatar
Default Re: how to remove quarter glass in 1929 model a tudor
Oz, first, welcome.
Not to put you off, but you can do a search on this topic. (see the tool bar above). It has been discussed many times before in great detail. But in short, it involves removing the screws on the support panels and pulling the panels out enough to remove the glass from below. The search will gain you some step-by-step info. Good luck. If after reading the previous posts you still have questions, come on back.
Ray Horton, Portland, OR
Old 08-06-2013, 08:41 PM   #3
oz1954
I got the glass out! After pulling all the headliner and window trim the glass came out of the top side,not the bottom.Whew! Hope this helps someone else.
Old 08-06-2013, 10:22 PM   #4
28ACoupe
28ACoupe's Avatar
Congrats on your first major tech job. Now that you have the bug, it will never stop.
1928 Model A Business Coupe
Rebuild picture gallery here
The light at the end of the tunnel has been turned off due to budget cuts.
28ACoupe is offline   Reply With Quote
