OH, the humanity of it all. Quality is just not what it used to be.
The entire float arm fell off, in the tank, of my new replacement gas gauge. ( I'm now rebuilding the original. ) |
I bet the repro gas gauge was made by Vintique. Why, oh why are many (most) repro made so poorly. Maybe we should be grateful that there are so many repro parts made for the model A, but it would be great if they made them a little better.
Rusty Nelson |
Yes, it was Vintique.
And it really ruined a great afternoon as it happened as I took the A out for it's first drive. I was just getting to the point of relaxing a little (you know...worrying about all the parts and did I put them in right and tighten them right and are all the cotter pins in, etc.) and I start hearing this tappy-clunking from in front of me. (tank only had 4 gallons in it for this test run). I pull over because I think I've got something going wrong with the engine...and the sound stops. If I hadn't, by pure chance, notice that there were no numbers in the window of the gas gauge I wonder if I would still be digging around under the hood. So, it's back in the garage with tape over the hole while I rebuild the old one and get a refund on this POS. (it looks like the end of the arm is threaded but the indicator doesn't seem to have matching threads.) |
But WHAT caused it to fall off? Was it abused/damaged/etc. Maybe it can be easily repaired, they're a simple gizmo! If is new, they should replace it!
By the way, I got a new locking door & rumble handle from Snyder's, made by VINTIQUE, & by damn, they look like quality & work beautifully-----They even got KEYS! Bill W.
#5 | |
![]() Quote:
WE OWE YOU ONE, BUDDY,
#9 | |
![]() Quote:
the total amount of time it spent in gas until it broke was less than 30 minutes. I am going to see if I can return it since I have repaired the original with a new floqt and hand cut gaskets. if now, I'll get a replacement and throw it on the shelf. |
#10 | |
![]() Quote:
I once had a perfect looking cutout, with a riveted on cover, that always stayed closed. When I opened it, the moveable arm was badly bent out of shape, as if someone dropped it or stepped on it just before the cover was riveted on! Watch out, in the past, some repro gas guages had a PLASTIC lens, that would melt & turn brown from the gas. I had 2 of them, they were O.K. after putting in a REAL glass lens. Bill W.
Whoa! Wait a second on the Toyota bashing...
I just bought a Tacoma 4X4 double cab to have enough grunt to tow my 29 CCPU! ![]() Everyone here told me my RAV4 wouldn't cut it... ![]() (Just kidding about the Toyota Bashing... ![]() P.S. Most Camrys are built in Georgetown, Ky. and most Tundras come from Texas!
"They can make me grow older, but they CAN'T make me grow up!" ![]() |
A wise man once said when you manufacture something you have three related measures of optimal unit outcome quantity, quality and cost . Unfortunately you only get two of the three Most parts suppliers opt for quantity and cost at the expense of quality. Sad fact is the number of people that are prepared to pay for quality is a lot less than the people who desire quality. -Karl
#13 |
I think you just learned another of the important lessons about Model A's. If it original rebuild it because most of the repo stuff is ill fitting junk.
#14 | |
![]() Quote:
![]() Only thing i can suggest is drive it till the fuel gets low then fish it out the fuel gauge hole with one of those spring loaded claw thingys they sell for like $2 Are you sure the new ones are threaded and not just ribbed for a press fit into the gauge read head? I would be tempted to JB weld the rod back in the hole.... Or if your origonal is good enough to rebuild id do that too.
#15 |
If you can't get your gas-gauge fixed - try Bert's in Colorado. Might as well be specific - Bert's has skads of all the various styles and types from the various years - all original. I would however, replace any cork floats with the new replacement "Won't Sink" (space-age 'plastic') floats available at the better Parts Houses.
#16 |
I can't believe nobody has blamed Ethanol for the failure yet.
#17 |
#18 |
I always laugh at ethanol comments. Ethenol has been used in gasoline since the 1900's and upwards of 25% by volume. (Standard Oil in the 1920's) It has never been a problem until marketers of new products created a problem to scare the public into change.
It wasn't a problem then and it isn't a problem now. |
#19 |
Last year I had the same thing happen when I installed a repo gauge in my Tudor. The problem was as Richard Wilson described in his post, and I repaired it exactly the same way Richard did. The JB Weld seems to be holding up well.
#20 |
I recently purchased an item from one of the popular "A" part suppliers that was totally inferior for it's intended use. In calling them they told me to send it back. My advice to them was if they agreed that it was inferior, to discontinue its sale. Such action is what separates good suppliers from some others and where my future business will go. Like so many things, it comes down to trust in the supplier to sell you items of expected quality.
