I need to replace the coolant pipe - welded bung has a leak when it gets hot and the replacement pipes seem cheaper than the time spent to reweld and repaint. My current pipe is not an original.
Should the pipe be painted black, or should it be unpainted stainless steel? I got confused when the Snyder's catalog called out an unpainted stainless pipe for the "show cars". I have only seen them painted black. |
They were painted black. If your interested in originality get a copy of the judging standards. Don't rely on information from vendor catalogs.
Yea black, the reference to the stainless steel and show cars is in it's shape and method of bending.
Be sure to buy the right shape. The bend is near the front of the pipe for 1928-9 Model A's and near the middle of the pipe for 1930-1 Model A's.
I installed an engine in a 1929 Tudor a few months ago that had the wrong pipe. It was hard to install and puts a lot of stress on the radiator bottom outlet. |
As stated above, the Model A Judging Standards & Restoration Guidelines should be your guide. There is an "Engine Compartment Finishes" table on page 1-18, although neither my edition (Revision 2011) of this page nor the Area 3: Cooling chapter appears to address the finish of the water return pipe. Perhaps someone more knowledgeable can point to where in then judging standards this information can be found. (The original edition of the judging standards contained a statement that "In the interest of preservation, the following options are acceptable: 1. Any item which was unfinished and subject to rust may be painted black..." but this appears to have been deleted from the most recent edition.)
Interestingly, page 3-7 (Revision 2011) Of the judging standards shows three water return pipes; 1928 thru 1929, 1930 thru June 1930 and July 1930 through the end of production (although there appears to be some confusion - to me at least - between the descriptive paragraph and the water pipe illustration caption; again, perhaps someone more knowledgeable can clarify this).
Skip Keyser Napa Valley A's Olympic Vintage Auto Club (1980-1982) MARC of San Diego (1977-1978) MAFCA (since 1978) MARC (since 1977) ---------- Model A owners belong in their Model A’s; Model A’s belong on the road. Last edited by Napa Skip; 07-26-2013 at 09:07 AM. Reason: typo |
I bead blast stainless to a matte finish and it holds paint well.
I just painted it right out of the box with Rustoleum Professional Spray paint. It's been a couple years with no hint of paint flaking off.
Thanks for the feedback - and the recommendation on the Judging Standards!
You can have the best of both worlds with a stainless pipe and powder coat it black. Be sure that you don't powder coat the inside of the pipe, only the outside.
'31 Fordor Deluxe 2W Briggs 170-B / blackwalls '41 Fordor Deluxe / 2-duece flattie '66 1/2 Dodge Charger '14 100th Anniversary Challenger Limited Edition. Semper Fidelis ![]() |
#12 | |
![]() Quote:
About 10 years ago I had my steel pipe powder coated inside and out, and within a few weeks all the inside powdercoating came off and was floating in the top tank of the radiator. ![]() |
#13 |
Tom, that's because the inside of the pipe wasn't sandblasted. If the slightest debris or even a figerprint(oil) on metal to be powdercoated is present, the coating will come off. A very close friend owns a powder coating business and uses a walk-in oven that I designed for him 15 years ago.
#14 | |
![]() Quote:
#15 |
Thanks Tom, that's good to know. I'll place that info in my old memory cells and hope it sticks.
#16 |
not to hijack this thread, but do you guys feel the '29 lower tank-to-hose connection is slightly angled and does not attach as smoothly as the later models, but rather seems slightly torqued?
#17 | |
![]() Quote:
![]() Sure glad my Model A doesn't have lines to leak. ![]() |
#18 |
Except for gas & water
#19 |
Bought a stainless pipe about 6 years ago.
Thought petcock was leaking -- with a flash light at night, crawled under to find the SS weld at the petcock joint was leaking very little. Soldered pin hole in pipe with silver solder, washed pipe with POR Marine Clean; etched with POR 15 Prep & Ready, (formerly called POR 15 Metal Prep); painted with (2) coats of POR 15, followed by POR Chassis Paint -- today, no leaks, looks new after (6) years. Because of no high pressure like in water supply pipes, silver solder will work on your pipe if the crack or hole is cleaned with something like paint thinner, then fluxed with silver solder flux, & finally soldered. BTW: (A flash light is wonderful water leak detector for roof leaks, automotive leaks, etc. -- each tiny "new" drop of water that emerges shines like a diamond.) Hope this helps. Last edited by H. L. Chauvin; 07-30-2013 at 02:12 PM. Reason: typo |
#20 |
Here is my 9-27-28 pipe. The radiator pipe and shroud are original parts. The outlet angles down and out slightly, and the pipe is bent to match. This is why you need the correct pipe, and not the 30-1 pipe on the 28-9 car.
