Old 06-20-2013, 04:10 PM   #1
charlesea
charlesea's Avatar
Default change to 16" wheels
I researched this question but did not find anything about tjis.
I have just installed a set of 16" wheels that came with my car to see if I would like the handle & ride. After installing them I found a set of open end lug nuts in the box of hub caps. Should I use that type lug nut or will the Model A lug nut be ok? Thanks
charlesea is offline   Reply With Quote
Old 06-20-2013, 04:38 PM   #2
Charles Coe
Charles Coe's Avatar
Default Re: change to 16" wheels
The model A lug nuts will work fine.
Charles Coe is offline   Reply With Quote
Old 06-20-2013, 04:41 PM   #3
62pan
I don't think it matters which style lug nuts you use. If they are 35 spoke wheels they should fit fine. Solid steel wheels sometimes dont seem to leave you much thread on the lug studs.
62pan is offline   Reply With Quote
Old 06-20-2013, 04:45 PM   #4
Charlie Stephens
If the 16 inch wheels are solid rims did you remember the adapter (assuming mechanical brakes)? If they are wire wheels there shouldn't be a problem (mechanical brakes). If you have hydraulic brakes post what you have. See
http://www.jalopyjournal.com/forum/s...ns#post8330045
If the lug nuts go all the way on without bottoming out there shouldn't be a problem.
Charlie Stephens
Old 06-20-2013, 05:02 PM   #5
jkeesey
jkeesey's Avatar
I used the original 1929 lug nuts on mine, no problems.
jkeesey is offline   Reply With Quote
Old 06-20-2013, 05:22 PM   #6
Purdy Swoft
Purdy Swoft's Avatar
The model A lugs will be best. The original lug nuts cover all of the threads and prevent rust.
Old 06-20-2013, 06:29 PM   #7
charlesea
charlesea's Avatar
Thanks for the thumbs up on the Model A Lug nuts. I thought so but wanted to hear it from others that have run other size wheels. I do have hydrolic brakes & they do have the spacers on the drums.
Old 06-20-2013, 07:48 PM   #8
glenn in camino
glenn in camino's Avatar
The lug nuts will work fine but your Model A will look funny with the wrong wheels.
Old 06-20-2013, 09:27 PM   #9
verrece
verrece's Avatar
Please, could you give us a Photo of your car with 16" weels?
thanks
verrece is offline   Reply With Quote
