Old 02-28-2015, 01:31 PM   #1
U.P. Ted61741
Default Multiple disc clutch
I have a MD clutch apart and need to replace 2 discs that are worn badly. I have read that I need a KR Wilson tool to get the clutch back together properly. First of all, does anyone reline these discs? Secondly, where do I find the KR Wilson tool?
U.P. Ted61741 is offline   Reply With Quote
Old 02-28-2015, 03:35 PM   #2
Tom Endy
Tom Endy's Avatar
Default Re: Multiple disc clutch
The individual disks can be re-lined by any clutch repair facility. The disks are much the same as a motorcycle clutch. A KRW alignment tool would be hard to come by, but you can fabricate a substitute using a board and some nails.
For more information about the multi-disk clutch go to the web site of the Santa Anita A's of Arcadia, CA at santaanitaas.org. On the home page put your cursor on "Technical Reference". My name will appear below, click on it. A library page will come up. There is an article there about the restoration of the multi-clutch.
This web site is not locked, you will be able to download and print out any of the articles. Feel free to do so as they are there for the benefit of the Model A hobby and anyone may use them.
Tom Endy
Tom Endy is online now   Reply With Quote
Old 02-28-2015, 03:48 PM   #3
johnbuckley
johnbuckley's Avatar
Originally Posted by Tom Endy View Post
...for more information about the multi-disk clutch go to the web site of the Santa Anita A's of Arcadia, CA at santaanitaas.org. On the home page put your cursor on "Technical Reference". My name will appear below, click on it. My name will come up. There is an article there about the restoration of the multi-clutch. This web site is not locked, you will be able to download and print out any of the articles. Feel free to do so as they are there for the benefit of the Model A hobby and anyone may use them. Tom Endy
here's the link and great articles they are too. Tom, thankyou. http://www.santaanitaas.org/technica...tech-articles/
Old 02-28-2015, 05:26 PM   #4
Charles Reese
Charles Reese's Avatar
Unless you have a neurosurgeon/facial reconstructive surgeon as a neighbor and a double platinum level ACA card, I recommend you NOT use a homemade rig to work on this part. I don’t know the exact amount of ‘spring’ in the spring, but I am comfortable it would easily disfigure a guy if it got loose!!! At this late stage in life, I have finally learned that things go better with the 'right tool'.
I would be willing to loan you my KRW tool for a short period. However, due to it's scarcity ($) I would request you cover postage (insured) and a 'security deposit' which i would return when i have the tool back in the same shape it came to you.
If interested, we can chat via the private message to the left of the page.
Fortunately, my discs were all in good shape and only needed cleaning before reassembly so I cannot guide you on where to have yours resurfaced. Surely another FB’r can guide you.
Charles Reese is offline   Reply With Quote
Old 03-02-2015, 08:21 AM   #5
U.P. Ted61741
Thank you for your quick reply. I might take you up on borrowing that tool, however, I'm going on vacation for about 3 weeks, so can I contact you when I return?
Thanks,
Ted Burson
Old 03-02-2015, 01:33 PM   #6
Brian-NJ
I disassembled and reassembled mine using a large stainless steel hose clamp, and 4 pieces of 1/4 diameter round bar. I have a photo here somewhere, just have to find it. clamb goes horizontal around clutch, round bar goes vertical between the teeth and clamp to keep it aligned. put under hydraulic press to put pressure on spring and remove 4 nuts. very easy.
Brian-NJ is offline   Reply With Quote
Old 03-02-2015, 04:39 PM   #7
Bob/Kansas City
Bob/Kansas City's Avatar
Charles Reese is right....that spring on the multi disc clutch is one of Ford's killer springs ! Best to use the right tool to be safe !
Bob/Kansas City is offline   Reply With Quote
Old 03-02-2015, 04:45 PM   #8
Tom Endy
Tom Endy's Avatar
If you don't have the proper KRW tool you can get it apart and reassemble using a shop press.
Tom Endy
Old 03-02-2015, 06:32 PM   #9
brito36
If you are careful you can re-assemble the clutch after you have the discs relined. Make sure that all the fingers are lined up. I did my own multi-disc clutch several years ago in my garage with only a limited amount of tools.
brito36 is offline   Reply With Quote
Old 03-03-2015, 06:09 PM   #10
U.P. Ted61741
Brian NJ, I thought someone would have a home-made tool that might work. thanks for the info. One question, I took two mdclutches apart. One had lock washers and one not. Do you know which is correct?
Old 03-03-2015, 06:41 PM   #11
d.j. moordigian
d.j. moordigian's Avatar
Well,...I have an NOS spring for the mutil-disc clutch. I had to push it in my
spring checker,....with a 1" press it has a spring rate of 140 pounds per inch.
If someone knows the "installed height", we will all know the installed pressure.
d.j. moordigian is offline   Reply With Quote
Old 03-03-2015, 06:54 PM   #12
Bob C
I'm not familiar with the MD clutch but the parts
book shows five lock washers.
Bob
Old 03-03-2015, 09:07 PM   #13
Tom Wesenberg
Tom Wesenberg's Avatar
Here is my multiplate clutch, and it has 5 internal tooth lock washers.
Old 03-03-2015, 11:01 PM   #14
Fullraceflathead
Fullraceflathead's Avatar
I believe Ford bragged about it being 397Lbs of pressure in either the early Owners Manuals or Service Bulletins.
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 12-24-2016, 04:40 AM   #15
RUNNERBUN
RUNNERBUN's Avatar
Post 15 reported
Adjust your points with gentle blows of a 2 pound hammer
RUNNERBUN is offline   Reply With Quote
Old 12-24-2016, 05:31 AM   #16
Mitch//pa
Originally Posted by RUNNERBUN View Post
Post 15 reported
U dont need to answer all the spammed threads. Just report one and ryan will fix it. By answering them all they will stay at the top instead of disappearing so ryan will have to delete your responses also. Double the work
