Old 03-23-2013, 07:38 PM   #1
wrndln
Default Camshaft question
Does anyone know what the height measurement of the camshaft lobes were originally? I know this probably isn't the best way to check a camshaft, but it is pretty easy to get a quick idea if the cam is worn very much. I have seen the diameter of the bearings (1.56") in books, but not the total height of the lobs. This can be easily be checked with a caliper. If anyone knows what this dimension is, would you please post it here.
Rusty Nelson
Old 03-23-2013, 08:05 PM   #2
Jazzjr
Jazzjr's Avatar
Default Re: Camshaft question
Here is a link with the lift specks, but it looks like they are taken from the center of the camshaft .779 to the high point of cam from center, .302 for the lift. as far as I can figure 1.256 bottom of round to high point of cam.
Center to top is .779 w/lift, so i subtract .302 the lift, from .779 is= .477 to 1/2 dia of cam.
Now .477 Twice= .954 + .302 = 1.256
Maybe you can determine something from the drawings, to use with your caliper, to get the sum you want to measure overall from bottom to top???
http://www.fordgarage.com/pages/camshaftspecs.htm
Jazzjr is offline   Reply With Quote
Old 03-23-2013, 10:10 PM   #3
Purdy Swoft
Purdy Swoft's Avatar
Bill Stipe told me for best results the center bearing needs to be 1.557. The center bearing was originally 1.560 The lobe height should be preferably not less than 1.225 This is the numbers that I looked for when I measured lots of cams before I found one that met these specs. We had our cam ground to the popular Super street Winfield 3/4 race. It idles good and coupled with a 5.9 head it gives better performance accross the rpm range . I think the lift is 314 . the original lift has been said to be 302 . Most cam grinders will grind what you send them. A center bearing diameter of 1.556 isn.t too bad but it gives the cam more room to rattle around in the block .
Old 03-24-2013, 01:56 AM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
Rusty, Vince has the information you want. I just compared it to my NOS camshaft and it's right on.
Old 03-24-2013, 09:33 AM   #5
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Rusty Nelson
Ummm, depending on the quality of the caliper, do not be alarmed if your camshaft does not match the specs on the print. You really need to use a micrometer instead if you are trying to make an accurate assessment as your calipers may be off as much as .002 - .004 and give you a false reading with regard to wear.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 03-24-2013, 12:44 PM   #6
wrndln
Thanks to all that responded. I have the information to tell the original height of the lobes. Brent, I would normally use a micrometer to get exact measurements, however calipers would be fine to get close. I keep forgetting how much great model A stuff is on Vince's website. I should maybe have his web address tattooed backwards on my forehead so when I look in the mirror, I remember to check his site more often.
Rusty Nelson
Old 03-24-2013, 02:15 PM   #7
hardtimes
hardtimes's Avatar
Rusty Nelson
Hey Rusty,
A or B...they are different..no?
