Old 03-17-2013, 06:30 PM   #1
Hunter
Default Center Clamp Mounting Hardware
The first picture is the way I mounted the center clamp on my May 29 Coupe. I mounted it this way because of you look at the JS (second picture from top) it shows the hidden line closest to the bumper. Thus I mounted it this way.
However I believe the clamp should be reversed.Which way is correct?
Thanks - Hunter
Hunter is offline   Reply With Quote
Old 03-17-2013, 06:40 PM   #2
Ron in Quincy
Ron in Quincy's Avatar
Default Re: Center Clamp Mounting Hardware
I believe the way you have it mounted is correct; it keeps the bumper upper and lower bars in line with one another.
This is the way I mounted my center bumper medalion on my Dec. 27 early vehicle.
Ron
Ron in Quincy is offline   Reply With Quote
Old 03-17-2013, 06:43 PM   #3
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Oh My! I have a new '29 center clamp to install, which way will I face the bar??? I hope I don't lose sleep tonight! Should it's background be painted blue? (Seriously!) Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 03-17-2013, 06:51 PM   #4
peters180a/170b
peters180a/170b's Avatar
the other way i don't think you will get the nut on.... as well.
peters180a/170b is offline   Reply With Quote
Old 03-18-2013, 12:31 AM   #5
Tudortomnz
Tudortomnz's Avatar
Mine is mounted the other way, but then it started life in Canada. Theory was that there should be a little tension if mounted opposite to your photo & stop centre medallion coming off? Will have to check other original cars now!
Tudortomnz is offline   Reply With Quote
Old 03-22-2013, 03:28 PM   #6
Hunter
Thanks all.
Peter I think you are correct, I don't see how this would work if turned around as the stud length would be too short.
At least it would be for the original center clamp that I have.
Thanks - Hunter
