05-31-2011, 04:35 PM | #1 |
Looking for Odd Maintenance Tips
For Example:
Simple Green is an inexpensive version of 409 that can be purchased at your local Dollar Store. (I first learned about it here on the Fordbarn.) I use it to clean around my zerks before, during, and after greasing. It is the ‘during’ part I thought I would share. Since grease and water do not mix, I spay around the zerks and the areas where the grease squeezes out with Simple Green. I leave it wet and fill the zerks with grease. The grease does not stick in the wet areas as well, making the squeeze-out easier to remove.
http://MODELABASICS.com/ How Things Work on a Model "A" Ford Fordbarners, Feel free to use the pictures on my site to answer questions and create tutorials/tech articles. |
05-31-2011, 05:05 PM | #2 |
Re: Looking for Odd Maintenance Tips
Hi,
good tips. Along with that, pump the grease in the zerk till it comes out clean grease. That makes sure new grease in in the joint. Replace any zerks that dont have the little chek ball in the end. The chk valve keeps the water, dirt, out and the grease in. Take care. Big al |
05-31-2011, 05:40 PM | #3 |
When you clean or remove your spark plugs, return them in different holes from wence they came
05-31-2011, 05:41 PM | #4 |
Whenever you remove the spark plugs squirt some oil in the chambers and the plug threads
05-31-2011, 06:31 PM | #5 |
Maybe a little off topic,but here goes. One of my favorite tips came from a older man that I worked with in the 70s. Try this the next time you need to remove a broken off bolt from a threaded hole. It the bolt broke off flush with the surface, cut a slot in the bolt with a cut off wheel, then try removing it with a screwdriver. I like to use a screwdriver with a square shank, then I can apply a little extra leverage with an adjustable wrench. This has saved me a lot of time over the years.
05-31-2011, 08:56 PM | #6 |
