Maybe not the correct place for a question regarding a Sun Machine, but here goes.
I would usually set up a distributor on a KRW fixture to set the dwell, points and initial timing. Then run on my Sun Machine to confirm the mechanical advance is working and check for point bounce. My question, it is possible to set marks on the machine to also set the initial timing on the machine? I know the 21A mark would differ from a 32-41 distributor, but does anybody do this? |
I use my sun machine to setup the the points, vacuum brake and initial timing. Do you have a copy of the instructions with your machine? It tells how it's done.
No I do not have instructions. I am trying to learn how one would set up a Early (32-41) distributor on a sun machine and be able to set the initial timing without the use of a KR wilson fixture.
I recently picked up this Sun Machine and am having fun with it and trying to learn. I understand how you could check the vacuum brake, points, dwell, and advance. I do not understand how you can set initial timing, without setting one up on a KRW fixture and then making a mark with a sharpie on the Sun Machine to mark where it should be. |
Mine has a small pointer at the 6 o'clock position . To set initial timing you run the distributor at slow enough speed to prevent the centrifugal weights from moving . Align the degree ring at Zero on the pointer. Then adjust the timing device on the distributor to 3 degrees advanced. 3 Degrees may not be correct, goin off memory. But that's how it's done. Remove the vacuum brake before setting the initial timing.
For proper case timing the distributor would need to be marked with the KW Wilson tool and then the adapter indexed in the sun machine for proper tdc...
#7 | |
![]() Quote:
I keep saying i am going to set up a machine ( i have more than one) but just never get it done...... |
Neither Ken nor 35fordtn have mentioned which model Sun machines they have. This is a very interesting subject to at least a few of us. I currently have 5 Sun testers, 4 504's and a 500.
Only 2 have the locating holes. None have arrows. Ken, you've said the arrow is at 6:00. What model Sun and does the arrow appear to be "factory" or added later? When the adapter pin is in the locating hole, does the machine strobe at 6:00? As is often said, "Nothing is as easy as it first appears." There may be more to indexing the early flathead distributors than just putting marks on the machine.
"Remember that when it comes to intelligence, half of all of us are below average." |
Mine is a DT-400. I just finished rebuilding it with a NOS flashtube, new capacitors, etc, etc.
My flathead adapter DOES have a locating pin, as does the clamp. It does have the arrow at 6 o'clock. The distributors when properly timed do not strobe at the arrow. and each distributor (21A vs 68, vs 40) do not strobe at the same locations. I still believe one could not possibly set initial timing on a Sun Machine. Even if you made your own mark for each style distributor on the machine, there are too many variable in this machine to make it a accurate way of setting initial timing. Just my thoughts I only wanted to see what others opinions were. |
#10 | |
![]() Quote:
Ken, does the machine strobe at the arrow?
#12 | |
![]() Quote:
#13 |
Ken, I want to verify that the machine actually strobes at the arrow. This is important in calibrating the unit.
Does the strobe occur at the arrow. It's not something I want to assume. Others do not. Does yours?
#14 |
No, it's only purpose is to zero the adjustable degree ring. if the degree ring isn't at zero then none of the readings will be correct.
#15 |
If it does not strobe at the arrow, how can you possibly set initial timing on the machine?
#16 |
Are you referring to the stationary pointer the Arrow?
#17 |
Thanks, Ken.
Setting the initial advance on a Sun machine has not been on my "do" list. There are other challenges ... led strobe, tach calibration tool, etc. I use the KRW along with the Sun which works fine. Let's see if I can nail down an exact, repeatable procedure on the Sun alone. (35fordtn, are you going to the swap meet at Fletcher, NC, this weekend?)
#18 |
We must have two or three different machines. My instruction booklet covers how to do it all including setting the initial timing, setting point dwell, setting the vacuum brake and checking the centrifugal advance.
#19 |
Sounds to me like you could make a fortune selling copies of your 'instruction booklet'....
#20 |
Is it possible for you to scan just the pages that explain it ... sometimes a photo of the page will do. I have a bunch of manuals but not what you have. The key is the way your machine is configured ... not that it is different. If I can see the instructions, I think I can figure out what's going on.
The early flathead distributor requires special indexing ... Thanks.
