05-18-2023, 06:32 PM | #1 |
Leaf Spring Question
I was wondering who sells the steel sleeves that fit into the leaf spring eyes? The sleeves are 7/8" OD x 3/4" ID with a wall thickness of 1/16" and an overall length of 1 3/4" and 2 1/4".
Thank you! Walt |
05-18-2023, 07:07 PM | #2 |
Re: Leaf Spring Question
sounds like someone drove the pins out and left the outer in the spring . the pin and case are one unit on cars . Two things year and model would help and a photo if possible often explains more than any thing else
05-19-2023, 01:00 PM | #3 |
The sleeve is not a separate item. It is an assembly with the stud and bushing.
Third Gen Auto has what you are looking for. Front: https://thirdgenauto.com/product/193...n-leaf-spring/ Rear: https://thirdgenauto.com/product/193...or-cotter-pin/ -or- https://thirdgenauto.com/product/193...to-the-spring/
WTB '33 Ford parts: * Sedan/Victoria front seat adjuster mechanism * Sedan/Victoria rear seat catch pieces (B-192921 and B-192964) * Sedan or Victoria roof tack strip (OEM or aftermarket) * Straight commercial (pickup) bumper '33/'34 or '35 (46-17757 or 68-17757) |
05-20-2023, 11:17 PM | #4 |
If you are restoring original, that is one thing.
If the car is to be just a "driver", you might research Delrin bushing kits. They last forever. NO special tools required to install. |
05-21-2023, 06:32 PM | #5 |
Thanks everyone for your input! I have the original NOS metal cartridge style shackle studs but I do not have the special tool needed to install them. I bought the "hot rod" style shackle kit but they do not include the 7/8" spring eye bushings. My thought was to insert a steel sleeve into the spring eyes and use all 3/4" bushings. The springs are for a '32-'34 car. Has anyone else ever encountered this problem?
05-21-2023, 08:08 PM | #6 |
Mike Wanted: - '32-34 Open Cab Pickup (RPU) parts and documents/articles/info - ARDUN parts |
05-22-2023, 06:33 AM | #7 |
32-34 springs used the 7/8" Dia. If you check with your supplier they usually have the proper size in stock, and you will not need the repair sleeves usually sold by bearing suppliers. It was 35-48 that used the 3/4" Dia.
