06-18-2019, 03:12 PM | #1 |
King pin kit
Hi guys
I bought a king pin kit from Rockauto and I tried to test fit the bushing on the pin buy hand and cannot even get it started. Are they normally that tight. |
06-18-2019, 03:19 PM | #2 |
Re: King pin kit
After installing they need robe fitted to the diameter of the pin, they should not fit over the pin either in or out till fitted
Perhaps reaming, but sunnen hone with long mandrel that goes through both bushings--- same if using reamer, reamer has to pilot off other bushing to keep both holes in line |
06-18-2019, 06:43 PM | #3 |
Re: King pin kit
The brass bushing needs to be line bored after installation so I would say that they should not fit over your king pin until installed and bored.
06-18-2019, 07:18 PM | #4 |
Re: King pin kit
Take the spindle and your bushings and pins to an automotive machine shop and have them fitted properly. There should be zero play.
06-20-2019, 09:26 AM | #5 |
Re: King pin kit
In the "old days" we tended to use what are called "king pin reamers" - pretty much everybody had them. They work okay - especially if they are new and designed to pickup both bushings. In today's world, I take the spindles to a machine shop that has long mandrel honing equipment - such that I have them "honed to fit" - and the pins should be a very tight fit. If they don't have a hone that picks up both bushings - then find another place - as both need to be sized at the same time (to keep the alignment correct). Another option is to get in touch with "Okie Joe" who drops axles - he can do the fitment for you (at least I had him do my 32 spindles when he dropped an axle for me). Good luck!
06-20-2019, 09:27 AM | #6 |
Re: King pin kit
www.joesspeedshop.com/joesproducts.htm |
06-20-2019, 10:21 AM | #7 |
Re: King pin kit
All good advice. I've seen too many people chuck up a reamer and ream one side and flip the spindle over and then do the other and can't figure out why they have to pound in the king pin.
06-26-2019, 01:48 PM | #8 |
Re: King pin kit
Got it guys. We got a reamer from a machine shop.. Thanks
