04-15-2022, 10:24 PM | #1 |
1959 Mercury Fuel Sending Unit
The fuel sending unit in my 1959 Mercury Monterey has seen better days. Does anyone know if the FSU from other years are compatible? I see some listed for 1957-1958, and they look similar, but the part is not listed as fitting the 1959 year cars. And I'm not finding anything for 1959 Mercurys (save one OEM FSU for like $280.00).
I see in the master parts catalog they have different part numbers. But I was hoping maybe the earlier FSU can be used (and work properly) in the 1959 cars. |
04-16-2022, 09:29 AM | #2 | |
Re: 1959 Mercury Fuel Sending Unit
- https://www.clocksandgauges.com/gas-...it-repair.html
- WANNA SEE A GOOD CAR WRECK? - https://www.youtube.com/watch?v=5oO226PgSkg KULTULZ - HAS MOVED ON TO THE HAPPY PROVING GROUNDS |
04-16-2022, 10:01 AM | #3 | |
I was wondering what the difference is that makes the 1959 FSU so unique. It looks very similar to the 1957-1958 unit. I'm tempted to buy a 57-58 unit and compare the the one I have. Last edited by Stephenorf; 04-16-2022 at 05:14 PM. |
04-19-2022, 11:00 AM | #4 |
Does anyone happen know the resistance reading on a fuel sending unit? I get ~12 ohms on empty (or full, not sure which way) to ~55 ohms on empty (or vice versa, as previously noted). I'm wondering in my fuel sending unit is still giving the correct signal. this is for a 1959 Mercury Monterey.
I looked in the Mercury Maintenance Manual but it doesn't seem to have operation specifications for the fuel sending unit. |
04-19-2022, 06:30 PM | #5 |
I don't know if that shop would give you specs they go by or not.
In a DLSHP, it either worked or not and was simply replaced.
04-19-2022, 10:42 PM | #6 |
