07-30-2016, 07:58 PM | #1 |
Water wetter
Is this good stuff or not?
07-30-2016, 08:14 PM | #2 |
Re: Water wetter
Water Wetter is good. I use it with distilled water and a small bottle of antirust/pump lube. No anti freeze in FL.
07-30-2016, 09:00 PM | #3 |
Re: Water wetter
I would add more corrosion inhibitor though, based on my experience.
07-30-2016, 09:26 PM | #4 |
Re: Water wetter
save your money ,fix your radiator,weter is junk
07-30-2016, 09:45 PM | #5 |
Re: Water wetter
Trying red line as a anti corrosion . good or bad ? it don,t freeze here , well not often ,
07-30-2016, 09:58 PM | #6 |
Re: Water wetter
07-30-2016, 10:14 PM | #7 |
Re: Water wetter
Same here!
07-30-2016, 10:24 PM | #8 |
Re: Water wetter
X3. I have not used it in my A, but I do in my 55 Chevy. I also would do whatever you need to do to fix any cooling system problems, THEN use the Water Wetter.
07-31-2016, 12:36 AM | #9 |
Re: Water wetter
i was told at a car show that water wetter is nothing more than laundry fabric softener at a
Horribly inflated price. Wayne |
07-31-2016, 01:27 AM | #10 |
Re: Water wetter
Has always worked well for me with distilled h2o.
... prosperity is not the product of charity but of industry - HENRY FORD |
07-31-2016, 04:47 AM | #11 |
Re: Water wetter
07-31-2016, 07:47 AM | #12 |
Re: Water wetter
I had terrible rust in an engine from using it for anti corrosion with water one summer. If you read the instructions it says for street use always use it with some antifreeze.
John |
07-31-2016, 08:10 AM | #13 |
Re: Water wetter
07-31-2016, 08:40 AM | #14 |
Re: Water wetter
07-31-2016, 09:10 AM | #15 |
Re: Water wetter
I thought water was WET
07-31-2016, 09:31 AM | #16 |
Re: Water wetter
07-31-2016, 09:40 AM | #17 |
Re: Water wetter
Dog here,
P.T. Barnum wunce sed, "There's one born every minute"!---Did he mean Elephants ur People??????------ Buster T.
07-31-2016, 09:45 AM | #18 |
Re: Water wetter
Ya think...maybe he wants to see more rusty cracked blocks it's good for business
07-31-2016, 11:45 AM | #19 |
Re: Water wetter
The principle behind "water wetter" is that it reduces the size and formation of bubbles at surfaces inside the engine water jacket. This enables better heat transfer from the engine to the coolant. In addition to Red Line, Amsoil also has it. Also, distilled (de-ionized) water might not be a good choice (as per instructions on Amsoil bottle). Water from a Reverse Osmosis system (if you have one) would be better.
Bill Newland |
07-31-2016, 12:09 PM | #20 |
Re: Water wetter
Just facts from experiences:
A. If one starts out with a "clean", and functional original Model A radiator and engine block that can function well in 115 degree heat; and B. If one uses only distilled water or rain water, as opposed to well water or spring water in constant contact with the earth's dissolved minerals; and, C. Mixed with 50/50 "Prestone" anti-freeze; D. Your original Model A radiator and block will continue to function faultlessly for at least over 55 years ...... from experience. E. Paragraph A. above, ignored constantly by so many Model A owners, is of utmost importance. Last edited by H. L. Chauvin; 07-31-2016 at 12:11 PM. Reason: typo |
