Old 02-18-2019, 07:33 AM   #1
Steve Plucker
Default Brake Rod Return Spring Confusion
The description and photo of the Brake Rod Return Springs in the 7-8 Revised 2011 of the Standards has some slight confusion within.
The confusion lies in the verbage of the Service Brake Rod Springs.
Within the verbage of the text it states that #2 was used from May 1928 through September 1928, that it was tapered with an open end and made of 19 or 20 gauge steel.
In the photo, it shows that #2 has a closed end and the verbage beneath the photo states that #2 was used from December 1927 through mid 1928.
#1 has a open end and used from May 1928 through September 1928.
Will someone in the know please set the story stright on the first two generation Service Brake Return Springs?
Thanks.
Pluck
Old 02-18-2019, 11:13 AM   #2
Jim Mason
Jim Mason's Avatar
Default Re: Brake Rod Return Spring Confusion
I had to read it a couple times also.
Ignore the numbering...it applies only to the photo not the sequence of release.
To match the photo the descriptions would be kabeleS 2,1,3,4,5,6
I wish they would have put the springs in the same order as the descriptions
Clear as mud
www.jmodela.coffeecup.com
Fwiw, jm.
Jim Mason is offline   Reply With Quote
Old 02-18-2019, 11:45 AM   #3
Steve Plucker
Thanks Jim for that.
So to make the "mud" clear...The verbage UNDER THE PHOTO is the correct sequence of these springs in relation to the photo...correct? In other words, the "photo" of the springs is out of order...Correct?
So for a July 1928 chassis, I would want the Service Spring with the open end as displayed and described in the photo?
What is "kabeleS"?
Pluck
Old 02-18-2019, 01:08 PM   #4
Jim Mason
Jim Mason's Avatar
Thats the way I interpret it.
Fwiw, jm.
Old 02-18-2019, 02:21 PM   #5
Steve Plucker
Along with this...It also states for the first generation spring in one area: "December 1927 through April 1928 (Early 1928)".
In another area below the photo it states: "December 1927 through mid 1928 (August 1928)".
OK...Which is correct?
Thanks.
Pluck
Old 02-18-2019, 03:15 PM   #6
Jim Mason
Jim Mason's Avatar
Also look at the front brake actuators dates in the drawing and the brake rod dates.
Not a well wrtten section
Fwiw, jm.
Old 02-19-2019, 08:18 AM   #7
Charlie jeep
Hi,
no chances to post a photo of the "Brake Rod Return Springs in the 7-8 Revised 2011" ??
A photo is better than a thousand words !
Tks
Charlie Saguier
Ford Model A Roaster Pickup 1928
Jeep Willys CJ-2A 1947
Jeep Willys MB Slat Grill 1942
Charlie jeep is offline   Reply With Quote
Old 02-19-2019, 08:46 AM   #8
Steve Plucker
UPDATE...
Besides the photo showing #1 and #2 out of place (in reverse progression order) as Jim mentions above, the caption below the picture is not correct. It should read: "December 1927 through April 1928", just like the text bullet describes in the Standards.
