04-17-2018, 06:07 PM | #1 |
Steering box question.
I'm pondering going back to my "original" steering box. I just pulled it out of the shed. It has the keyed shaft. The only markings are an "F" and a 7 embossed on it. What do I have?
04-18-2018, 02:41 PM | #2 |
Re: Steering box question.
Hope this helps
2-Tooth Steering Gear Housing Casting Markings DatesGemmerFord February - May 1929“GEMMER” & “PAT. PDG.” in raised lettersRaised “F” on the side February - May 1929“GEMMER” & “PAT. PENDING” in indented lettersRaised “F” on the side April 1929 - Mid 1930“GEMMER” & “PATENTED” in indented lettersRaised “F” on the side January 1930 - EndNo IDIndented “A-3550-C” on the engine side January 1930 - EndNo IDIndented “A-3550-C” on the engine side & raised 5/16" or 9/16" letter “F” on the other side Except for minor machining differences, all the above housings are virtually identical mechanically & all new parts furnished will fit each one. Ford & Gemmer were the two manufacturers of the 2-tooth steering box. All parts are interchangeable, exceptthe worm gear, 2 races & 2 bearings. The Ford box has a large “F” on the outside where the worms are located. This change was made in December of 1930 (See page 518 Service Bulletins). The Ford box used a #9 roller bearing, while the Gemmer box used a #13 roller bearing. This also changes the taper on the bearings & races. The only parts available today are for the Gemmer box; therefore, if you have the Ford box with #9 roller bearings & it becomes necessary to change any of the 5 parts, then you must convert to all 5 of the Gemmer components (A3524CD, (2) BB3571, A3553D, BB3552) |
04-18-2018, 03:30 PM | #3 |
Also this about the steering shafts
04-18-2018, 03:32 PM | #4 |
Sorry it looks bad I will try to improve it
04-18-2018, 04:02 PM | #5 |
