06-12-2018, 06:43 PM | #1 |
Fuse block ideas
My 29 Tudor has been converted to 12 volts and I want to put a fuse blocks on the fire wall. Any ideas??
My thanks to all who responded,didn't know I had that many options, I knew the barners would come through. I went with the one by Eagle. Liked the led feature and size. I am mounting it on the outside firewall. Last edited by Ray baker; 06-17-2018 at 08:54 AM. |
06-12-2018, 07:26 PM | #2 |
Re: Fuse block ideas
Painless sells a universal fuse block that has no wire so you can use original styled wire
Sent from my SM-G930V using Tapatalk |
06-12-2018, 07:26 PM | #3 |
06-12-2018, 07:32 PM | #4 |
I found this fuse block on google. I also found the power distribution post.
I mounted both using Velcro tape. I know this is overkill, but it works for me. |
06-12-2018, 08:25 PM | #5 |
Bratton's sells one called an A-Plate that attached to the inside of the firewall. A little bit hard to get to for me.
06-13-2018, 11:27 AM | #6 | |
06-13-2018, 02:26 PM | #7 |
06-13-2018, 04:38 PM | #8 |
I made my own mounting plate and bought a fuse block from Amazon. No holes were drilled and mounting is to existing location above kick panel on left side and the right side I used a longer screw for the cable clamp next to the junction block on front of firewall. and it is held with a nut on the screw on the inside.
06-14-2018, 01:17 AM | #9 |
I use the same one as Dennis, I also got it from Amazon, but you can get it from most any marine supply house. Brand name is BlueSeas. I modified mine so that 6 of the terminals are switched with the ignition, the other 6 are on all the time. I mounted it to the firewall in the engine compartment with Velcro tape. If you want something smaller (ie: less than 12 terminals) they make all sorts of configurations.
06-14-2018, 10:46 AM | #10 |
These terminal blocks also have 7 ground terminals, one of which can be used to connect to a battery cable ground.
06-14-2018, 12:02 PM | #11 |
I believe Logo Lites makes the A-Plate mentioned above.
http://www.logolites.com/gallery/ngg...ctures/A-Plate David Serrano |
06-14-2018, 01:48 PM | #12 |
I like to use one like Eagle suggested, but I always use two of them. One is hot all the time, the other is switched. I use a 40amp relay on the switched one so the key switch is not overloaded.
I like those fuse panels because they are small, hold blade fuses, 6 of them, and an led turns on to indicate a blown fuse. You can mount all this on a hunk of metal that bolts to the firewall on some existing bolts or holes. Just what I do...
Corley ----------------- Subscribed to the KISS principle! |
06-16-2018, 10:32 AM | #13 |
I did SIMPLE, BOUGHT 3 G.M. blade type circuit breakers, with Pig Tail leads. Spliced a 30 Amp one in the YELLOW feed wire at the starter. Spliced 2, 20 Amp ones into the HORN & LIGHTS feed wires, near the CUT-OUT & it worked QUITE WELL.
Bill Simpleasshit
