10-29-2014, 04:20 PM | #1 |
Flathead exhaust valve guide seals
Are seals used and or needed for the exhaust valves on the 8BA engine?
Thanks
"This thing better run when I get done!" |
10-29-2014, 04:31 PM | #2 |
Re: Flathead exhaust valve guide seals
Intakes only. And then use the O'ring type rather than the square ones which are a bear to install without them shearing.
10-29-2014, 06:35 PM | #3 |
I use never seize on the exhaust and RTV on the intakes
10-29-2014, 06:44 PM | #4 |
Ol Ron,
No seals on either? John |
10-29-2014, 08:13 PM | #5 |
I'm with Ron on no seals in either. I use a little hi temp RTV on the intakes.
10-29-2014, 10:24 PM | #6 |
10-30-2014, 02:33 PM | #7 |
Ol' Ron - The knurling makes sense to me but being an electrical engineer I don't know how it is done. Do you have to take the guides to a shop or can you do it yourself?
10-30-2014, 03:43 PM | #8 |
I do mine in a lathe now, however I did them in a vice with a fixture I made out of wood to hold the guide while I ran the knurling tool, and the reamer. Most auto machine shops should have the tools
06-01-2015, 10:26 PM | #9 |
BTTT: Here is how I just did it:
Here is the problem - all the guides I've ever used are fairly loose in the guide bore. This is something that I 'fix' with knurling. When Ron talks about knurling, he is talking about the traditional knurling of the valve guide bore to tighten up guide bore to valve stem clearances. I know some experienced racers that won't knurl flathead valve guides (especially the exhaust), they install bronze liners. The reason is that they want better heat transfer from the valve stem to the guide and tightly fitting bronze liners do this supposedly better than a knurled cast iron one. Video: The problem with loose fitting guides (in the block): https://www.youtube.com/watch?v=qZBXFMqHs-c Here is the knurling process and final result: Video: Knurling: https://www.youtube.com/watch?v=UqYqBIy1BAI Here are some final guide pictures - you can see my spring spacers for the Isky 185-G springs as well as the cut-back section I do on the top of the valve guides (so they don't obstruct the port). Enjoy: KnurledIntakeGuide copy.jpg FinishedGuides1 copy.jpg Last edited by Bored&Stroked; 06-02-2015 at 07:48 AM. |
06-01-2015, 11:14 PM | #10 |
Knurel is a good friend of mine!
06-02-2015, 07:24 AM | #11 |
I don't bother to Knurell the outside of the guide the RTV takes up the room between the guide and block. However, doilg this will probably center the guide and grinding the seat with the knurelled guide in place will make a true seat. My valve grinding fixture locates on the guide bore.
BUT, we haven't addressed the stem to guide clearance here. |
04-22-2024, 08:40 AM | #12 |
I'm still wondering what is considered proper stem to guide clearance for 8ba? Not showing up in a search.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1946 Tonner Pickup with 226 H six, 1979 Toyota landcruiser wagon, now wearing 1947 Ford Jailbar sheet metal. 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
04-22-2024, 10:55 AM | #13 | |
04-22-2024, 02:51 PM | #14 |
On one hand knurling the outside is good because it makes the guide tight in the block so the valve seat remains solid in place but you also lose about 30% contact area which relates to a LOT of heat transfer capability.
In a street engine you may not notice the shorter life. |
