Old 08-05-2018, 06:18 AM   #1
codeplus
Default model a motor
Does anyone know what a running 29 model A motor is worth? Thanks
codeplus is offline   Reply With Quote
Old 08-05-2018, 07:06 AM   #2
Paul Bjarnason
Default Re: model a motor
I have seen them go for a few hundred dollars. But, check it out and if: while running the coolant looks good and there are no bubbles, there's no undue water coming out of the exhaust, the oil looks fairly clean with no evidence of water in the oil (i.e., no whiteness to the oil), the block looks clean with no apparent leaks, the compression is an even 60 lbs or better across all four cylinders, and if you can stick a borescope into the cylinders and things look good, I would try to get it for $500, but be prepared to pay as much as $1,000.
Paul Bjarnason is offline   Reply With Quote
Old 08-05-2018, 08:42 AM   #3
aermotor
IMO $1000 is too much without a complete inspection of the bottom end in addition to the above. Bottom end rework will probably cost more than the above if all needed attention.
John
aermotor is offline   Reply With Quote
Old 08-05-2018, 12:12 PM   #4
Jim Brierley
I agree with aermotor. I have sold complete but dis-assembled A short blocks for $75.
Old 08-06-2018, 07:36 PM   #5
eagle
eagle's Avatar
All depends on what "running" means. If the block is good and known repairable, couple hundred...a newly properly rebuilt engine could be a few thousand. Can't help you much but its a pretty open question.
Old 08-07-2018, 05:55 AM   #6
Step-down
Step-down's Avatar
I just traded a 4 banger and transmission for a 1940 V8 and tranny both in usable
Condition
"I can't cry as long as I know the Lord has risen "
Step-down is offline   Reply With Quote
