Old 08-14-2012, 04:23 PM   #1
47COE
47COE's Avatar
Default Temperature sender: one or two?
I'm working on a 1941 COE truck with 59-AB engine. It has just one temperature sender, apparently standard practice in 1941.
My 47 COE has two senders.
Should I get a two prong sender and wire it like the later engines? Or is one good enough?
I don't plan to enter it for point judging. I just want a reliable truck.
Tom
47COE is offline   Reply With Quote
Old 08-14-2012, 07:52 PM   #2
paul2748
paul2748's Avatar
Default Re: Temperature sender: one or two?
If you have two regular senders (not the double post one used in cars) you can run one gauge by wiring them into a double pole switch (toggle switch works good) and then one wire to the gauge. Flip the switch and you can see the temperature on one side or the other.
Old 08-14-2012, 08:38 PM   #3
bige386
bige386's Avatar
I have two temp gauges in my 46. Its set up three in a row. Temp , oil , Temp. They are hooked up independent from one another. It works for me.
The Lord is the light--allow Him to guide you.
bige386 is offline   Reply With Quote
Old 08-15-2012, 12:38 AM   #4
47COE
47COE's Avatar
Two votes for reading each side.
Adding a toggle switch is definitely easier than adding a gauge. I'll think about that option.
Tom
Old 08-15-2012, 07:55 AM   #5
Henry/Kokomo
Henry/Kokomo's Avatar
One more option. . . . I have the stock gauge wired to a single post temp sensor on the left (typically cooler) cylinder head and an after-market temperature gauge installed on the right (typically hotter) cylinder head. I did this after installing a rebuilt engine. By using the two gauges, I can see how hot the engine is running compared to the previous engine (used same sending unit and same stock gauge) as well as getting a temperature reading, in degrees F., from the after-market gauge. I admit its probably overkill. FWIW
Henry/Kokomo is offline   Reply With Quote
Old 08-15-2012, 08:48 AM   #6
41LjH
41LjH's Avatar
One sensor will monitor one side of the engine. If you use two sensors, one one post and one two post daisy changed together the single post becomes the "O' S**T sensor". Went the single post activates the stock gauge shows max deflection or max hot. Either two gauges or a toggle switch and two sensors with one gauge allows more accurate monitoring of both sides of the engine.
3 pedals, 3 gears, no valve-covers..
Now THAT is a hot rod !!
https://www.youtube.com/watch?v=ZmwwB34vxJE
41LjH is offline   Reply With Quote
Old 08-15-2012, 12:27 PM   #7
Newc
Newc's Avatar
Hi Tom; Just remember that those senders are listed new for $65!!!! Call me if you need a used one, and save all you find. Newc [Dale N]
Old 08-15-2012, 01:57 PM   #8
47COE
47COE's Avatar
Originally Posted by 41LjH View Post
When the single post activates the stock gauge shows max deflection or max hot.
I thought it was the other way around. The two post left hand side is the one that just switches to max. hot while the one post right hand side actually measures temperature.
To read both heads with one gauge and a switch, I'd need two single post senders?
Tom
Old 08-15-2012, 02:00 PM   #9
47COE
47COE's Avatar
Dale, they certainly aren't cheap but aren't quite $65. Bob Drake has them for $60 and Macs for $50.
Do they ever go bad?
We can talk about it at the picnic tonight.
Tom
Old 08-16-2012, 10:03 PM   #10
Rand
Rand's Avatar
How can a guy test them to see if its accurate or not?
Randy
Rand is offline   Reply With Quote
Old 08-17-2012, 05:56 AM   #11
41LjH
41LjH's Avatar
"To read both heads with one gauge and a switch, I'd need two single post senders?"
Yes and make sure the senders are compatible with the gauge. Personally I use an electric Stewart Warner gauge and SW senders.
Old 08-17-2012, 06:45 AM   #12
rotorwrench
rotorwrench's Avatar
[QUOTE=Rand;480756]How can a guy test them to see if its accurate or not?
You can test any temperature monitor system if you have a hot plate, a pan of oil (oil won't boil over like water but I use synthetic oil that won't catch fire either), an accurate thermometer, and some jumper leads to connect the system to temp senders strategically suspended in the pan of oil on the hot plate. Ground paths have to be observed too so I usually use a partially insulated copper wire to wrap around the sender to suspend it in the pan. The wire must be insulated from the pan and have a way to connect to it and then connect back to the ground path on the vehicle.
If your thermometer or pyrometer to check the hot oil temp is accurate, you can see how far off the vehicles temperature indication is from the actual temp of the test media. You can also test the temp sensitive switch that the later vehicles use this way. You will know exactly what temp the switch opens at.
Old 08-17-2012, 05:35 PM   #13
Graeme / New Zealand
Graeme / New Zealand's Avatar
Tom
Go for a good second hand one. The repops are rubbish. I've had 2 go on me.
GB
"you can't make honey out of dog sh*t"
"You're a long time looking at the lid"
Graeme / New Zealand is offline   Reply With Quote
