Old 03-16-2012, 11:13 PM   #1
Juls
Default Cleaing out a Model A gas tank
Several years ago I decided to purchase my great grandmother's 1929 Model A. Seeing as though I'm a mechanically challenged female it may not have been the best decision. The car is in original condition and I use to drive it around the neighborhood until the rust in the gas tank became an issue. It has been in the garage up on blocks for probably close to 10 years and I'm looking for away to clean up the tank so I can start driving it again. Any ideas?
Juls is offline   Reply With Quote
Old 03-17-2012, 12:00 AM   #2
Hicktick
Hicktick's Avatar
Default Re: Cleaing out a Model A gas tank
Mam , if you would post where you are located , I am sure some one close to you will help you get it running . THere are clubs almost everywhere .
Pops I dont know so im tole .
Hicktick is offline   Reply With Quote
Old 03-17-2012, 12:29 AM   #3
Mike V. Florida
Mike V. Florida's Avatar
Congrats on the purshase!
Will all the mechanically chanllenged males on this board please raise your hands...100-102-103
The best decision you could have made was to keep the old girl in the family!!!
Get a couple of gallons of acetone. drain the gas add the acetone. shake the car and drain. filter the acetone through a cloth and do it again until the color is real dark and does not get darker and repeat with clean acetone. This will get alot of the "gunk" off the bottom of the tank and alot of rust as well.
I would then install an in the tank filter.
Also go to the two major Model A clubs and look for a local branch near you.
http://www.mafca.com/chapters_list.html
http://modelaford.org/pdf/RegionList.pdf
Old 03-17-2012, 09:27 AM   #4
John LaVoy
John LaVoy's Avatar
You might consider using the product Evapo Rust once you have removed as much of the crud as you can. With out removing the gas tank sealing it with a product is virtually impossible because of the baffles in the tank that would keep the sealer from reaching the outer portions of the tank.
John LaVoy is offline   Reply With Quote
Old 03-17-2012, 09:35 PM   #5
real550A
real550A's Avatar
After you get your tank cleaned out, I'd highly suggest NOT to store the car with ethanol/gasoline in the tank. Alcohol absorbs moisture from the outside air, and causes water to build up in your tank.
(we used to add HEET (alcohol) to our tanks to get the water out) That worked when the vehicle was being driven, not stored.
Mike B.
Model A's and Porsches since 1957
real550A is offline   Reply With Quote
Old 03-17-2012, 11:44 PM   #6
Mike V. Florida
Also remember the ratio, a pint of HEET to even a 1/2 a tank was well under the 10% we have today.
Old 03-18-2012, 03:39 PM   #7
KGBnut
KGBnut's Avatar
As a decent temporary fix, you can get a couple of powerful magnets. Just climb under the dash and put a few of them right on the tank in ring around the fuel valve. The larger pieces of rust will be attracted to the magnets and avoid clogging the fuel outlet. The sediment bowl will take care of the smaller pieces.
I like the 'pencil filters,' but they can block the last pint or so of fuel if you are running low. Also, using the magnets doesn't require draining the tank.
Do a Google Search for "neodymium magnets."
Style beats speed any day, and with a lot fewer tickets.
KGBnut is offline   Reply With Quote
Old 03-18-2012, 05:38 PM   #8
mstover
mstover's Avatar
Juls:
I just bought a '30 Coupe which turns out had a bunch of rust in gas tank. After talking with several people, it became clear the only sure-fire way to solve the problem was to take the tank off. I'm proud to say that this morning, I successfully performed my first gas tank-ectomy. It really wasn't that hard... just take one step at a time.
- Mike
Michael E. Stover, CPA/ABV
Living Life in the Slow Lane
2004 Beneteau 331, 1930 Ford Model A 45-B Coupe
www.sailtherapy.weebly.com
mstover is offline   Reply With Quote
Old 03-19-2012, 08:35 PM   #9
JBohannon
If you do decide to use the acetone method beware it is more dangerous than even gasoline. No smoking or sparks !!!
JBohannon is offline   Reply With Quote
Old 03-19-2012, 08:39 PM   #10
Elcastor
Elcastor's Avatar
I think the best advice was join a local club and there will probably be LOTS of help offered!
Ben Purkey
Mexico and the Pacific NW
http://www.martin-parry.com/
Elcastor is offline   Reply With Quote
Old 03-21-2012, 05:17 PM   #11
Tom Cavallaro
Tom Cavallaro's Avatar
As an Electrician, I used my battery charger to finish the job. I used Evaporust…expensive. I used Vinegar…cheap. I used baking soda to naturalize the vinegar. Then I used the electrolysis. I used a piece of all thread and wood to insulate the rod from the sides of the filler neck. I connected the negative side of the charger to the tank valve at the bottom of the tank, and the positive side of the charger to the threaded rod which goes all the way in the tank but about a half inch off the bottom. 10 amps for about 6 hrs. and keeping a hose running to keep the foam from hurting the paint, and keeping the tank full, to get the rust at the top too. I’m now running off my tank with filters in the tank as suggested above, and in line before the carb. No problems for six months now. For the mix in the tank I used baking soda, two boxes, and a teaspoon of salt, and fill with water. When full, turn on the charger and watch the bubbles. Don’t smoke while doing this. The bubbles are Hydrogen gas. By the way…rust never goes to a magnet!
Tom Cavallaro is offline   Reply With Quote
Old 03-21-2012, 06:12 PM   #12
RcT
Right you are about magnets and rust... I had to google this up and, yep, you are correct. So include this one with the old blurb about "magnets on your fuel line will give you better gas milage"...
RcT is offline   Reply With Quote
Old 03-22-2012, 09:40 AM   #13
KGBnut
KGBnut's Avatar
You are absolutely correct, pure ferrous oxide is not ferromagnetic, but the stuff I have found in my tanks usually has a fair amount of unoxidized iron...and that sticks to magnets. On some tanks I have lowered in a bunch of ring magnets on a rope and they come out covered in rusty bits.
Don't get me wrong...this is a temporary band-aid and you are much better off to have the tanks properly cleaned and repaired, but this technique has gotten me home.
Old 03-22-2012, 10:29 AM   #14
b ramsey
i took mine out, poured a box of 100 1/2" nuts in there and some water, after plugging the fuel guage hole. shook it like a madman and then cleaned it all out. then washed the insides with swimming pool acid and then cleaned all that out. then coated it with red-kote. not the stuff you get in calif. i got it from a farm store in illinois. no problems since and im happy.
b ramsey is offline   Reply With Quote
Old 03-22-2012, 11:40 AM   #15
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Just curious how you got all of those nuts behind the baffles onto the sides of those baffles and at the top where the rust generally is located? That has been what I have seen when guys try to use this procedure is the center section always looks really clean yet the rust still is in the outer areas because the stones/gravel/BBs/nuts could not get behind the baffles.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 03-22-2012, 02:01 PM   #16
RcT
This reminds me of what I heard long ago about the hot rodders in southern California... they used to take their exhaust manifold, fill them about half full of sand and seal the openings. Then they would fasten the manifold to one of those oil rigs that bobs up and down all day long, pumping oil. Supposedly, the inside of the manifold wouls look like it had been chromed... smooth and clean.
Old 03-22-2012, 12:38 PM   #17
b ramsey
there is space for them them to get back there. getting them all back out is not hard just takes a few minutes of strategic shaking. whatever rust is still there, was sealed with the red-kote. but the nuts got all the loose scale. im not sayin it looks perfect and brand new inside, but at least it is now useable again, and thats what i was goin for.
Old 03-22-2012, 01:05 PM   #18
roadster31
Send it to Brent; he did one for me, it looks brand new inside and out! well worth the $$$ --- gas tank, not a spot to pinch pennies. EL
roadster31 is offline   Reply With Quote
Old 03-22-2012, 07:58 PM   #19
Tom Cavallaro
When I cleaned my motorcycle gas tank I used lead shot from about ten shells. That and a pint of gasoline everyday for a week shake shake shake, looked good been running for 15 years now. With the model a, I didn't want to take the tank out because of recking the paint. I want to drive...not keep fixing..LOL. With the electrolysis, everywhere the rust was is jet black. Every place else is shiney.
Old 03-22-2012, 08:09 PM   #20
BRENT in 10-uh-C
I thought electrolysis was line-of-sight only? Is it not?
BRENT in 10-uh-C
