I've installed Flathead Ted's brake system at all 4 corners.
I'm looking for information about adjusting the Flathead Ted brakes. I'm following the instructions from Model A Times. For instance, these mention turning in the adjusting bolts on the front brakes until the brakes start to drag, adjusting to get the brakes to lock up, and adjusting to eliminate pull. Do these instructions (and those for the rear brakes) replace the process described in Les Andrew's book? I'm guessing that this is so, but I would love to have this confirmed by someone who's actually done the conversion. Thanks much. |
Adjust like instructions say, not like original brakes . I have installed 3 sets and they work like modern brakes.
I agree with Jerry. You want the front brakes to come on first, not like the original brakes. I also made sure that the wheels turned freely without drag. I found that with drag the brakes were too aggressive. You will love these brakes!!
Dick |
I agree, with Flathead's syetem the fronts should come in first. Adjust them 60\40 favoring the fronts. Adjust the shoes in until the shoes just touch the drums. This way you can tell if the shop turned the drums round, arced the shoes correctly, and the installer centered them correctly. Then back them off until they do not drag.
Tom Endy |
Thanks to all of you....I really appreciate the help.
One part confuses me - easily done these days. ![]() |
Just so you know Les Andrews wrote the article in the Model A Times regarding the Flathead Ted brake floaters.
Thanks, Jerry. I was guessing that this was the case. I'm going to test drive the car this afternoon and work on getting the adjuster screws set properly per the instructions.
Will following the Model A Times version of the instructions automatically result in the 60/40 braking action mentioned in Tom's post? (Assuming, of course, that the braking system is otherwise set up properly.) John - interesting that Les wrote those instructions. I'm trying to follow them closely but find the description of the final adjusting process a little vague - unlike his very explicit instructions for adjusting stock brakes. Maybe it's because one adjusts Flathead Ted's by driving the car and tweaking things rather than using a couple of tools in the shop in one session. ![]() Last edited by Pilotdave; 02-26-2012 at 09:07 AM. |
Pilotdave: Flathead ted posts regularly on the EV8 forum. He may have some suggestions/updates, but will answer any question you might have. I also thought there was a video available someplace but that might be for regular A brakes. Hope this helps.
Paul in CT |
Thanks, Paul. I'll take a look on the V8 Forum....never been on it.
I can see adjusting the fronts so they engage more early than the rears, but the 60/40 ratio is built into the system by the different length of the center cross shaft arms. I doubt you can adjust the fronts to 60% given that the arm length applies more force to the rears. I bet the best you could do is 50/50.
#12 | |
![]() Quote:
http://www.abarnyard.com/ |
#13 |
Very interesting, Pat and Marcos.
So.....why not follow the stock brake adjusting approach (Andrews Vol I) with the Flathead Ted floating brakes? I'm not enthused about having the front brakes lock up before the rears....wouldn't that invite directional instability? I am going to try the stock approach first and see if I like that outcome. |
#14 |
I would ask Flathead. It is his design and his recommendation.
Tom Endy |
#15 |
Correct me if I am wrong but doesn't the locking up refer to the status of the wheels while being adjusted when the cars is jacked up? On the road would be different due to the front wheels handling the majority of the weight?
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound |
#16 |
Tom, I will do some research on the road this afternoon and also try to reach Flathead Ted.
Frank, I don't think so. Here is step 27 (adjusting front brakes) from the Andrews version of the instructions: "Road test the brakes. The brakes should start to react with about 3/4” of brake pedal movement. At about 10 mph apply full brake pedal. The car may pull to one side. Drive slowly for about 5 miles and softly work the brakes. This will self center the brake shoes. If the brakes will not lock up, return to the garage and slightly tighten the adjusters, only 1/4 turn at a time. Spin the wheels to ensure there is little or no drag. Road test again with slow stops and a full pedal stop. Full lockup should occur at no more than 1/2 pedal travel. If car pulls to one side, tighten the opposite brake adjuster slightly." I'm reading this to say that I should be able to lock up the front brakes on the road...yes? Will report back. |
