Old 10-22-2011, 08:35 PM   #1
47 flatbed
47 flatbed's Avatar
Default Dead flathead
I am now convinced that these motors are garabage. After this rebuilt motor getting way hot in about 2 miles and now water in the oil its over I am throwing in the towel. Will someone please tell me why this old technology is so sought after.
47 flatbed is offline   Reply With Quote
Old 10-22-2011, 08:46 PM   #2
jack orchard
Default Re: Dead flathead
if you build em right, they "work fine-last long time".
it is up to you to make sure they are right. stuck thermostat?
jack orchard is offline   Reply With Quote
Old 10-22-2011, 09:18 PM   #3
Junknshit
Banned
Something was for sure wrong, after 2 miles it shouldn't have maybe just reached something around operating temp, if that high. Put together right, they are tough old motors. Maybe I spoke too soon, without knowing, but I am assuming you mean a flatty 8.
Junknshit is offline   Reply With Quote
Old 10-22-2011, 09:20 PM   #4
makemc
makemc's Avatar
I have put many, many trouble free miles on my garbage engine.
Im sorry for your bad luck,I know its frustrating, but these are great little
engines if its built right. just dont put a chevy in that nice ford..
makemc is offline   Reply With Quote
Old 10-22-2011, 09:21 PM   #5
quickchange34
quickchange34's Avatar
The word "rebuilt" means different things to different people.To some it means a set of rings. To others it means all new moving parts. Block cleaned, tested and bored. Crank turned and Balance. Rods checked. New pistons, rings and wrist pins. Cam and cam bearings. Oil pump. Rod and main bearings. Dont forget it it takes alot of time to check everything when you put it together or it will still bite you in the butt.
quickchange34 is offline   Reply With Quote
Old 10-22-2011, 09:24 PM   #6
37ford4dr
37ford4dr's Avatar
sorry for your misfortune, its sought after because its not a SBC
37ford4dr is offline   Reply With Quote
Old 10-22-2011, 09:49 PM   #7
1931 flamingo
1931 flamingo's Avatar
How about refreshing our memories as I know you've posted before about your troubles. What was your original problem? What did you do to rectify? What was done before this most recent failure?
Flatheads (V8's) have been around for about 79 years, so can't be all that bad.
Paul in CT
Old 10-22-2011, 09:57 PM   #8
47 flatbed
47 flatbed's Avatar
Here is my list of expensive parts
block was cooked mag and machined
rods and crank balanced
new valve train springs valves retainer adj lifters
30 over pistons
all bearings, connectors and oil pump new
cam, distubitor and heads were about the only thing besides block that is old
The idea was to build an engine that I could drive on a fairly consistantly as a daily driver wasn't looking for a race car motor just a reliable daily driver. Now it neither. The truck is basically original and wanted to keep it that way double clutching and manual steering was fine by me.
Old 10-22-2011, 10:01 PM   #9
47 flatbed
47 flatbed's Avatar
I drove this truck for about 3 weeks now after valve train problems. Adj lifter self adjusting. Tonight she decided to get warm then just simply puked. I noticed a bit of moisture in oil friday morning but ran fine to my shop and this moring. Tonight it just got crazy hot.
Old 10-22-2011, 10:58 PM   #10
47 flatbed
47 flatbed's Avatar
I also forgot new stromberg carb, electric fuel pump and regulator radiator was pressure checked and cleaned.
Old 10-22-2011, 11:47 PM   #11
Mr 42
Mr 42's Avatar
After checking the obvious is it really over heating or is it the gauge??
Is it stuck thermostat. is the radiator up to it?
Id never clean a radiator i have a new core installed, and a known good carburator and distributor.
Most of the time overheating is caused by not enough advanced timing.
Try to adjust the distributor for max advance and listen after ping instead.
Then back of as bit.
Then retighten the heads, put in a can of Bars Leak.
Change oil and drive
And Ford never used adjustable lifters!
But if you still convinced that the engine is a piece of garbage, let somone else have a go at it ,and put in a bellybutton sbc,
Mr 42 is offline   Reply With Quote
Old 10-23-2011, 12:35 AM   #12
Tinker
Tinker's Avatar
One of the first things I do with a new car is recore the radiator. Water pumps a must too. 42 is right about timing. Just because it's new in the box doesn't mean it's timed right.
If the engine was rebuilt right and you use a crappy radiator it's doomed.
Just something as simple as a radiator cap (+7lbs) could be causing you problems.
Remember flatheads have been around for decades.
Old 10-23-2011, 12:39 AM   #13
Tinker
Tinker's Avatar
Okay re-read. Valve trian problems, what does that mean? Also was your dizzy rebuilt and timed?
Old 10-23-2011, 07:36 AM   #14
47 flatbed
47 flatbed's Avatar
When I bought this truck the first thing I did was replace water pumps. Cleaned radiator. Changed points converted to 12 volt and the old truck started from a 20+ yr sleep. Drove it for few hundred miles and could hear a little bearing noise so decided to freshen the motor had everthing pretty much dialed in to run at that point.On fresh motor had some adj lifters decide to adj themself I relapped valves in and fixed that issue and it ran awesome for less than 3 weeks then it took a big puke.
Old 10-23-2011, 07:37 AM   #15
47 flatbed
47 flatbed's Avatar
42 bars leak? I think that may cause more problems then it will fix.
Old 10-23-2011, 07:39 AM   #16
47 flatbed
47 flatbed's Avatar
I think before I go sbc I will do a ford motor gas or diesel. no way a chebby motor will go in there like everyone else does that kinda why this I left it in hell the truck is well more than double my age
Old 10-23-2011, 07:54 AM   #17
JWL
The first place I would look would be at the head gaskets. It is very possible one has begun to leak combustion gas into the coolant system. No radiator, new or old, can exchange that much heat. If water is entering the oil from a blown head gasket you might be able to remove the sparkplugs, crank the engine, and watch for water to be forced out of a sparkplug hole.
Were the head fasteners torqued properly to no more than 50 ft. lbs? Were they re-torqued at least 2 times when engine was cold after being operated at full normal temperature? Are the head and block gasket surfaces completely flat and smooth?
JWL is offline   Reply With Quote
Old 10-23-2011, 08:03 AM   #18
chuck stevens
chuck stevens's Avatar
47 flatbed, DON'T give up. I think your best bet is to find an old timer close by that likes to get his hands dirty. If you are going to tackle it yourself, take one thing at a time. Flatheads are sensitive to ignition timing, running to lean, and when fresh sometimes the extra friction will make then run warm. Pressure test the cooling system, to find where the coolant is getting in the oil. These old v8s are as dependable as the owner makes them. I just ran my 39, stock as the day it was made, 1500 miles in 4 days the only thing that gave me trouble was the fuel pump.
chuck stevens is offline   Reply With Quote
Old 10-23-2011, 08:17 AM   #19
jimTN
JWL has my thoughts on the head gasket thing. Do you have studs or bolts for the heads? Bolts have a way of bottoming out and not pulling the head down if the holes have not been chased. Also, the lifter thing sounds like a reground cam with std lenght adjustable lifter screws. They are too short for reground cams, proper adjustable lifters have a very thick head.
Old 10-23-2011, 08:21 AM   #20
George/Maine
George/Maine's Avatar
When I got my 39 with and 8ba engine it was running hot.Even in 30 degs weather couldn,t get 8 miles with out over heating.
I bought a new Walker Raditor and in testing with no water caused my water pump to leaks and burned my temp gauge.
I had engine out to do other things.
So i bought new waterpumps,still not runing temp gauge and running over year now with no problem.With 2 water pumps running you can push a lot of water.I,d get a new rad.
George/Maine is offline   Reply With Quote
