Old 01-02-2013, 08:58 AM   #1
Henry/Kokomo
Henry/Kokomo's Avatar
Default Oil Pan Trouble
I acquired a '50 Mercury oil pan with the windage tray for my 8ba engine. Since it was a bit rough and very dirty, I took it to a friend's shop and he ran it through his "shake and bake" cleaner. Burned off all the oil and crud and thoroughly cleaned the pan inside and out. After the cleaning, I had to leave the project for a couple of weeks. The pan was left in a heated garage but it developed surface rust on all surfaces. Anybody have any suggestions for removing the surface rust from UNDER the windage tray? Will the products that chemically convert rust to a black coating work on the inside of an oil pan? Any suggestions appreciated.
Henry/Kokomo is offline   Reply With Quote
Old 01-02-2013, 09:09 AM   #2
Scott H in Wheaton
Scott H in Wheaton's Avatar
Default Re: Oil Pan Trouble
Soak it in plain white vinegar. No chemicals to worry about.
Scott H in Wheaton is offline   Reply With Quote
Old 01-02-2013, 09:16 AM   #3
texas webb
Works.Rinse and light oil so it does not flash again.
texas webb is offline   Reply With Quote
Old 01-02-2013, 07:16 PM   #4
Henry/Kokomo
Thanks, guys. It seems I overlooked the obvious. I appreciate the help.
Old 01-02-2013, 08:09 PM   #5
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
Did you remove the aluminum dip stick thingy that is riveted to the side of the pan before the bakeing oven? If you didn'nt it isn'r there anymore. Walt
Old 01-02-2013, 08:11 PM   #6
Marcus
Marcus's Avatar
Wink Re: Oil Pan Trouble
Henry - One more tip: DRY the pan with compressed air after soaking, THEN a light oil coating to prevent flashing - seems obvious, but don't ask how I know better......NOW! HUGE GRIN!!
WARM REGARDS, MARCUS
Marcus is offline   Reply With Quote
Old 01-02-2013, 08:14 PM   #7
Henry/Kokomo
Walt - Yes I did! I didn't think it would fair too well being heated to 400+* and then having steel shot thrown at it. I cleaned it up in the bead blast cabinet. The internal threads are worn but they're still in place. Thanks for the note.
Old 01-02-2013, 08:15 PM   #8
Andy
I like to put Ospho on raw steel. It really protects it.
Do you need the oil pump and pick up that has the rest ofthe windage tray package?
Andy is offline   Reply With Quote
Old 01-02-2013, 08:16 PM   #9
Henry/Kokomo
Marcus - It's very easy to overlook the seemingly obvious - at least for me. Thanks for the reminder!
Old 01-02-2013, 08:18 PM   #10
Henry/Kokomo
Andy - Is Ospho a phosphatizing agent? Not familiar with the product. Who has it for sale? Thanks for the information.
Old 01-02-2013, 08:27 PM   #11
Ronnie
Ronnie's Avatar
http://virtualindian.org/2techclean.htm
http://www.eci.aero/pdf/09-2.pdf
R
Ronnie is offline   Reply With Quote
Old 01-02-2013, 09:10 PM   #12
Henry/Kokomo
Ronnie - Pretty serious stuff in the links you posted. Since the dipstick tube base hasn't been re-attached to the pan AND the threads are worn, I think a total replacement is in order. Many thanks.
Old 01-02-2013, 09:11 PM   #13
BillM
BillM's Avatar
See : http://www.ospho.com/
My web page:
http://myplace.frontier.com/~wgmumaw/
BillM is offline   Reply With Quote
Old 01-03-2013, 12:13 PM   #14
Chris Nelson
Chris Nelson's Avatar
Henry;
You can get Ospho from any paint store or hardware store.
Chris Nelson is offline   Reply With Quote
Old 01-03-2013, 12:33 PM   #15
Henry/Kokomo
BillM and Chris - many thanks for the info. Looks like an interesting product . . . which I intend to try. Thanks again!
