Old 07-05-2025, 05:47 AM   #1
2speed
Default Distributor Intermediate Shaft
While monkeying with the distributor, I noticed that the distributor does not fully seat in the head. Took out the intermediate drive shaft, and compared it to some old originals and it's .050 inches longer. Even the old ones were a little long.
Using a new drive assembly on the cam, and the head may have been surfaced, although I'm not sure that much.
Are these things trimmed to fit normally? I chucked it up in a lathe and shortened it up and everything is much smoother now....
2speed is offline   Reply With Quote
Old 07-05-2025, 06:41 AM   #2
BButturff
BButturff's Avatar
Default Re: Distributor Intermediate Shaft
I had to shorten one about that much last fall. Plus the notch was too narrow and I had to widen that about 0.020" as well. Reproduction part...
_______________________
The other Bruce in Minnesota
1931 Model A Closed Cab (Budd) Pickup "Aurora"
Model A Ford Club of America
Lady Slipper A's
BButturff is offline   Reply With Quote
Old 07-05-2025, 08:49 AM   #3
Richard Knight
I find the slots need file work to make them fit at both ends without binding.
Richard Knight is offline   Reply With Quote
Old 07-06-2025, 11:47 AM   #4
Phil Brown
Phil Brown's Avatar
Sad that something as simple as a shaft with a slot cut in each end can not even be made correctly to day. So simple to make and yet they find a way to screw it up....except for the part about processing payment
Phil Brown is offline   Reply With Quote
Old 07-06-2025, 11:58 AM   #5
JayJay
I've had a couple of the aftermarket lower shafts not fit into the upper shaft coupling. I think the slots are milled a bit off-spec. I've had to turn a few thousanths off the diameter to get them to fit properly. Avoid messing with the slot if you can, other than softening the edges. The tight fit of the slot onto the tang of the upper shaft is what assures that the timing doesn't wander.
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
Old 07-06-2025, 12:14 PM   #6
Kurt in NJ
Kurt in NJ's Avatar
Debris in the drive gear can also keep itron fully seating
