Old 06-21-2025, 03:46 PM   #1
Chris Haynes
Chris Haynes's Avatar
Default Looking for a '40's/'50's electric fuel pump.
During the over 75 years that my '32 was parked a few things came up missing. I am trying to return it to its 1953 appearance. The electric fuel pump was mounted on a substantial bracket on the firewall. I have no idea what this pump looked like. It feed three Stromberg's. I would like to find one.
I really wish that posting pictures here wasn't so difficult.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 06-21-2025, 04:26 PM   #2
Flathead
Flathead's Avatar
Default Re: Looking for a '40's/'50's electric fuel pump.
A pump that old won't like the ethanol blended fuel we have now. You could use it as a dummy and hide a modern pump under the car.
Flathead is offline   Reply With Quote
Old 06-21-2025, 07:21 PM   #3
nkaminar
nkaminar's Avatar
Here is one:
https://www.ebay.com/itm/17670168212...Bk9SR9LEhdDyZQ
As Flathead said it may not like ethanol. You could take it apart to see if any of the rubber components swelled in modern gasoline blend. Or run straight gasoline.
Old 06-22-2025, 04:40 PM   #4
Chris Haynes
Originally Posted by nkaminar View Post
Here is one:
I found several on eBay that may fit the mount. Thanks for the tip.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 06-22-2025, 04:40 PM   #5
G Baese
G Baese's Avatar
Chris I sent you a pm since I was unable to put a photo up of a 40-50"s 6v pump.
G Baese is offline   Reply With Quote
Old 06-22-2025, 07:02 PM   #6
CarlG
CarlG's Avatar
Several years ago I tried to find a Stewart Warner pump that was bolted to the firewall similar to the coil, but they were long gone from the planet.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 06-23-2025, 09:36 AM   #7
ModelA29
ModelA29's Avatar
Originally Posted by CarlG View Post
..... Stewart Warner pump long gone from the planet.
Still around - but pricey. There are plenty of vintage ones from the 60 but they are even more since people are using them to restore big dollar vintage cars and racers like Cobras.
https://www.summitracing.com/parts/s...SABEgKWvvD_BwE
ModelA29 is offline   Reply With Quote
Old 06-23-2025, 09:55 AM   #8
katy
katy's Avatar
The ones I remember from the' 50s stood vertical, were round, about 2" diameter and about 6" high, had a bracket like a ignition coil uses, don't remember the brand. Didn't look like the one at Summit.
FWIW, I've heard that some 12V pumps will work on 6V.
Old 06-26-2025, 12:40 PM   #9
ModelA29
ModelA29's Avatar
Yes - some are basically just an electromagnet. It gets energized and it pulls a rod that pushes a diaphragm. When it reaches it's limit the contact opens and a spring returns the diaphragm to pump the gas. There are check valves on the in and out sides to assure the fuel goes one way. These are (were?) commonly called "click clack" pumps.
Old 06-24-2025, 08:24 AM   #10
nkaminar
nkaminar's Avatar
Here is a photo of the brackets for the vintage fuel pump for Chris's car. He sent the photo to me so that I could post it.
