Engaged starter and all current went dead throughout the vehicle. Unhooked batter cables and had current coming from battery but everything dies when connecting cable back on starter. Engine cranks OK with hand crank so not jammed. Not good!
Starter bushings may be shot. Time to check it for rotation. It may also have e a short somewhere in there. This assumes that you've already checked the battery and cabling.
Dying battery
Put a battery tester on it to see if battery is OK. May have 6 volts but under load drops off
I am also going to go with the dead battery. Did you check the electrolyte levels?
Thanks much, I shall put all this wisdom to good use. Blessings.
why not help it with a hand crank?
