Old 02-03-2025, 01:21 PM   #1
Masot
Default Pressure Plate 9" diaphragm
Hi guys.
Do you know the model of pressure plate with diaphragm for 9" to adapt?
I looked at information on the forum and only saw 10" on rockauto
https://www.rockauto.com/en/catalog/...ure+plate,1988
Thanks
Masot is offline   Reply With Quote
Old 02-03-2025, 03:43 PM   #2
paul2748
paul2748's Avatar
Default Re: Pressure Plate 9" diaphragm
Go look at the Centerforce websight
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 02-03-2025, 04:05 PM   #3
tinkirk
tinkirk's Avatar
Look at early mustangs
I have one in mine but can’t remember the model id was supposed to fit
Did a lot of looking to find it
tinkirk is offline   Reply With Quote
Old 02-04-2025, 04:56 PM   #4
Masot
Thanks.
I read that with a more powerful engine it is better to have a 10" clutch disc. I am going to install a diaphragm pressure disc and fit a 10" clutch disc for my Volvo five-speed gearbox.
Old 02-04-2025, 07:56 PM   #5
Ronnieroadster
Ronnieroadster's Avatar
The 10 inch diameter is a much better idea. You will be happy with that decision.
Ronnieroadster
I use the F word a lot no not that word these words Flathead, Focus and Finish
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block
First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921
First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587
Old 02-05-2025, 09:02 AM   #6
Masot
Thanks Ronnie!
Old 02-05-2025, 11:27 AM   #7
Bored&Stroked
Bored&Stroked's Avatar
What transmission and throw-out bearing are you using? Many of the modern diaphragm clutch plates have fingers that do not "bend up" toward the tips. This is fine with a smaller diameter throw-out bearing (like we have on modern transmissions), but it can be an issue if you're using a 32 - 48 Ford transmission with the big-wide throw-out bearing.
What can happen is the throw-out bearing OD hits the diaphragm fingers in the "middle" of them - instead of on the ends/center when depressed. This is NOT how the clutch is supposed to work and can cause issues.
I recently had a well-known clutch manufacturer test their diaphragm pressure plates with the wide Ford bearing (as they were pushing me toward a diaphragm clutch).
After placing their clutch/disc in a test jig (using a 32 - 48 throw-out bearing) they came back to me and recommended that I NOT use their diaphragm pressure plates for this application.
I think they were a bit surprised when they actually tested their clutch setup. This caused them to switch me over to a Ford Long style pressure plate. They saw the issue I was mentioning when they actually tested their clutch setups with a wide bearing.
Just something to think about!
Old 02-05-2025, 07:26 PM   #8
Lawrie
Lawrie's Avatar
Thank You
Lawrie
Old 02-06-2025, 11:49 AM   #9
Tim Ayers
Please tell us who this manufacturer was so we'll know for future reference.
Old 02-07-2025, 10:41 AM   #10
Bored&Stroked
Hey Tim: I had a couple custom steel flywheels and clutch plates/discs made by RAM (to my specifications). I wanted the billet flywheels to be light (24 lbs) -- so they are back-cut and scalloped (see the picture). The set below will finally get installed in my 32 Cab in the coming months.
We discussed the whole diaphragm issue and I had them check their clutch plates.
Some diaphragm manufacturers have fingers that are designed (the ends of them) to deal with this situation . . . but buying off of Rock Auto . . . may not be the best thing!
