I have a Touring engine plus a tillotson Model X carburetor. Would an air maze air cleaner have enough capacity for this engine. Since the carburetor is and air balanced carburetor running and air cleaner should not be a problem. Any advice would be appreciated. Gerald
#2 | |
![]() Quote:
#3 | |
![]() Quote:
"My Model A... work never ends, only the day ends!" |
#4 | |
![]() Quote:
How did you air balance this carb? Can I see some pix? That's cool.
Jim Cannon Former MAFCA Technical Director ![]() "Spread the Joy! Have a Model A day!" |
The breathing of a Model A engine is restricted by the size of the stock carburetor and stock intake manifold. Adding that air filter will not change the performance. Adding an air filter to a carburetor that is not air balanced can cause the engine to run rich, depending on the restriction of the filter.
A is for apple, green as the sky. Step on the gas, for tomorrow I die. Forget the brakes, they really don't work. The clutch always sticks, and starts with a jerk. My car grows red hair, and flies through the air. Driving's a blast, a blast from the past. Last edited by nkaminar; 01-18-2025 at 03:09 PM. |
Bob Bidonde |
Pretty happy with a Highboy and low restriction K&N filter on my 31.
I would get rid of that paper filter and replace with steel mesh.
Unless all your driving is on dirt roads there's no obvious benefit to have a filter anyways. Henry did not have them at the factory. I had one for my Zenith for 15 years and never had an issue then I decided to remove it for some pictures and kept it off. No issues without one for the last 12 years.
1928 "A" Phaeton (mid year with many early features) 1933 "V8" Closed-Cab Pickup Truck (originally a Model B, 4 Cylinder dating to May, 1933)
I am a big believer in an air filter. My original AirMaze has the metal element that I clean periodically, then dip in oil and let dry. It is REALLY dirty when I wash it. If you use a paper filter I think its best to invert it so it doesn't get gas saturated and then catch fire.
