Old 12-02-2024, 04:40 PM   #1
Tonys1928A
Default Inserts I'm not sure what I've got going on here.
I'm new to owning a Model A,and I've got a few questions like what size inserts would I need or how to measure for the insert.Or are am I looking at it wrong and they are babbets?
Tonys1928A is offline   Reply With Quote
Old 12-02-2024, 04:49 PM   #2
Seth Swoboda
Seth Swoboda's Avatar
Default Re: Inserts I'm not sure what I've got going on here.
Should be babbitt if it's still stock Ford.
Old 12-02-2024, 06:38 PM   #3
J Franklin
J Franklin's Avatar
What problem are you trying to cure?
Old 12-02-2024, 07:05 PM   #4
rotorwrench
rotorwrench's Avatar
Crank and connecting rod journals are poured babbitt. Many times they can be adjusted by removal of the cap shims but it depends on condition of each bearing assembly. There are still folks that re-pour babbitt and machine it for best fit. There are also conversions for removable bearing shells but it takes machine work to do that.
New Burtz blocks are available as an alternative to overhaul.
Old 12-02-2024, 09:20 PM   #5
700rpm
700rpm's Avatar
Tony, if this is your first adventure into owning a Model A, I think you’re reaching in too Deep. Tampering with the engine takes a lot of experience, knowledge, money, and special tools. "Go slowly for a more harmonious outcome." :::Old Soiux saying.
Ray Horton, Portland, OR
Old 12-03-2024, 09:32 AM   #6
old31
Tony please explain whay you are asking about the inserts vs babbits.
Are you currently having a knock, or noise or is the engine not running?
old31 is offline   Reply With Quote
Old 12-03-2024, 09:49 AM   #7
Fullraceflathead
Fullraceflathead's Avatar
If you already have the engine opened up please send some pictures.
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 12-03-2024, 10:11 AM   #8
nkaminar
nkaminar's Avatar
Tony, where are you located?
Old 12-03-2024, 11:15 AM   #9
Tonys1928A
Sorry I just found out how to post pics
Old 12-03-2024, 11:18 AM   #10
Tonys1928A
Sorry I just found out how to post pictures
Old 12-03-2024, 11:23 AM   #11
Tonys1928A
Cocoa Florida
Old 12-03-2024, 11:44 AM   #12
1930artdeco
1930artdeco's Avatar
You have Babbitt bearings that have failed or are about to fail. There are +/- to each bearing.
Babbitt is adjustable and forgiving of grit that gets in them and you can 'farmer' it if you absolutely have to-to get you home if you don't have a AAA card. The downside is that they must be installed correctly or they will come apart and there fewer and fewer places doing them correctly anymore.
Shells-most machines shops who know about Model A motors can do them nowadays and they will last you a very long time if done right. Downside is that any grit will shred them and you will be doing a rebuild.
This is the gyst of the differences of the bearings and I am sure that people smarter than me will chime in.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 12-03-2024, 12:58 PM   #13
J and M Machine
Location: 40 Mt.Vickery Rd. Southborough,MA 508-460-0733
Yes they are babbitt bearings and there is no saving those if you are going to drive it. Those bearings are also lead babbitt ,doesn't last long.
A good machine shop will use tin base babbitt as shown in two pictures enclosed.
J and M Machine is offline   Reply With Quote
Old 12-03-2024, 01:11 PM   #14
rich b
rich b's Avatar
And to think our forefathers repaired these engines in primitive working areas with minimum tools.
rich b is online now   Reply With Quote
Old 12-03-2024, 06:50 PM   #15
nkaminar
nkaminar's Avatar
Tony, You should not be afraid to work on your Model A. They are very simple and a good car to learn on. Buy the redbook, link below. J & M in Post #13 is right, the bearings will need to be repoured and remachined. Best to take it somewhere. Or look around for a used engine in good condition. Or buy a Burtz Block.
https://www.snydersantiqueauto.com/p...0031&cat=41621
Old 12-03-2024, 07:55 PM   #16
ThirstyThirty
ThirstyThirty's Avatar
I was going to add: "should be thin babbitt..." but i see OP has posted pix.
the broken corner dosen't bother me as much as the wafer thin babbitt... in old days they used bacon rinds in there 'tween rods, mains and the babbitt. the old timers say it worked!!
you can also hand scrap in a new babbitt bearing cap. and that works, too! just have to get the running clearance correct.
am thinking those mains 'groaned' noticeably under low rpm, high load conditions...
"My Model A... work never ends, only the day ends!"
ThirstyThirty is offline   Reply With Quote
Old 12-03-2024, 08:00 PM   #17
ThirstyThirty
'Indeed!'
Old 12-05-2024, 01:20 PM   #18
rotorwrench
They also used the tongues out of old military type boots but these "fixes" don't last very long.
As the crank is ground down to smaller under sizes, the babbitt has to be thicker and thicker. A person doing the pouring also has to know the best way to peen the babbitt before align boring to size. The babbitt tends to shrink a bit on something as large as an engine block so peeing the surfaces is important. Babbitt journal bearing re-work is an art form that takes a while to learn. It's better to find someone with a lot of experience to do these type of jobs.
