Old 09-25-2024, 04:57 AM   #1
fordscript
fordscript's Avatar
Default 40-41 pu tailgate
Could someone tell me the inside diameter of the tailgate hinge 'rolled tube' at the bottom of the tailgate? i believe the diameter of the tailgate hinge is 3/4 inch and assume this goes direct into the tailgate.My tailgate is so beat up, its hard to tell what its meant to be.Thanks.
fordscript is offline   Reply With Quote
Old 09-25-2024, 07:12 AM   #2
ActionYobbo
ActionYobbo's Avatar
Default Re: 40-41 pu tailgate
I am currently rebuilding my 39 tailgate and assume it’s 7/8id the same as the top roll as 3/4id is too small and 1id is too big
I am building a 1939 1 ton express
ActionYobbo is offline   Reply With Quote
Old 10-04-2024, 07:09 AM   #3
rustynut4247
rustynut4247's Avatar
the id of the roll is i inch and uses a 18 ga bushing .045 making the hinge hole .910 . the hinge roll is .880 dia northern classic trucks
rustynut4247 is offline   Reply With Quote
Old 10-04-2024, 04:40 PM   #4
fordscript
fordscript's Avatar
Thanks for your help guys. Most helpful.
Old 10-04-2024, 05:52 PM   #5
pistonbroke
Jus a fyi on 41 and later gates. the upper roll is not uniform all the way across. It stays the same size verticly and the inside or front edge is straight but it should have a bow outward of maybe a half to three quarters of an inch. I can only assume they did this for strength as the earlier ones were very easy to warp and bend. Tim
Old 10-05-2024, 10:26 PM   #6
expavr
expavr's Avatar
The upper roll on my 40 Tonner tail gate also tapers out 1/2” from each side to the middle of the gate. Another possible reason for the taper is that it fits the hand better making it easier to lift the gate from the horizontal position.
expavr is offline   Reply With Quote
