Old 08-13-2021, 06:46 AM   #1
Ken B
Ken B's Avatar
Default Model A C-Cab project
Well my dream of making a C-Cab delivery is finally in the works. I have had a lot of fun steam bending the wood pieces. I have no plans or prints to go by so I am scaling from some good pictures. My question is does anyone know where I can find the back door hardware like in the attached pictures? I want to have door handle mechanisms on both doors. Thanks in advance for any advice.
File Type: jpg $(KGrHqJ,!mIFJps,EdIiBScEI)zt5g~~60_3.jpg (86.9 KB, 199 views)
File Type: jpg 1931_Model_A_Frod_Panel_Delivery-jun9dBut.jpg (21.1 KB, 192 views)
Ken B is offline   Reply With Quote
Old 08-13-2021, 09:02 AM   #2
ronn
Default Re: Model A C-Cab project
your best chance would be ebay.......and it'll take time and patience.
I have found some incredibly rare stuff there over the yrs.
another option is to machine your own, using common door handles from an A and working from there.
Old 08-13-2021, 09:07 AM   #3
ronn
sorry- photo didnt come up- mechanism for similar delivery...........ebay
Old 08-13-2021, 09:38 AM   #4
katy
katy's Avatar
Got pictures?
Old 08-13-2021, 09:56 AM   #5
Keith True
Keith True's Avatar
If you have any junkyards around you can find that exact hardware on the inside of the doors on old step vans.Those parts would be on the left inside of the double doors.The right opens from the outside,then you reach in and open the left.The problem with that is when scrap skyrocketed about 10-12 years ago the yards cleaned up.When the yards would run one of those vans over the scales and bring hom $13-$1500.they didn't want to keep many to sell $10.parts.You might want to look at a place called,Mill Supply,I think it's in New Jersey.That is where I have always bought step van parts.headlight doors,heater and fan parts,but most of all window and door hardware.
Old 08-13-2021, 01:03 PM   #6
Ken B
Ken B's Avatar
The one on Ebay isn't the style I am looking for. I am looking for the mechanism with the upper and lower rods that insert into the upper and lower framing. The junkyard option might be kind of fun to dig too. The search goes on. Here are a couple pictures of what I am working on. I restore old Victrolas and this will have the Victor logos on the side. I have an old Victrola still in the shipping crate and a Nipper radiator ornament (my avatar)for it also.
Old 08-13-2021, 01:25 PM   #7
rich b
rich b's Avatar
Maybe check Austin Hardware; we used to get latches and stuff there when we custom built cabs and utility box covers. Used to be something like a rotary handle with link rods going to spring loaded latches on the top and bottom.
Old 08-13-2021, 02:49 PM   #8
springerpete
springerpete's Avatar
Might check Bert's in Denver as they have a huge inventory of Model A stuff. You never know.
springerpete is offline   Reply With Quote
Old 08-13-2021, 05:14 PM   #9
mercman from oz
mercman from oz's Avatar
Your Project is coming along nicely - keep up the good work.
Old 08-13-2021, 08:31 PM   #10
Ken B
Ken B's Avatar
Thanks for suggesting Mill Supply!!! It looks like they have exactly what I am looking for. https://www.millsupply.com/slam-latc...a.php?p=323034
Old 08-14-2021, 07:12 AM   #11
Keith True
Keith True's Avatar
I've used that setup in a horizontal application,so I just made solid rods instead of using the cables.
Old 08-14-2021, 08:30 AM   #12
Ruth
Thanks for the heads up on Mill Supply. I don't need anything at the moment but saving link for future.
Ruth
Old 08-14-2021, 09:59 AM   #13
Ken B
Ken B's Avatar
The link goes to the one with rods and not the cables. This should work great for what I am doing.
Old 07-11-2024, 03:38 PM   #14
Ken B
Ken B's Avatar
After a very long period of time where this project got back burnered, I am back on it. I have the body pretty much made. I am getting ready to skin out the body. I am hoping to use 1/4" plywood. My question would be whether the plywood would be able to with stand the heat of the sun without having any blistering issues. There are several grades of plywood but I'm not sure which one to use. Any suggestions? I plan on priming and painting it. The plywood would also need to be a bit flexible to curve inwards towards the bottom. Thanks in advance for any suggestions on the plywood.
Old 07-11-2024, 05:14 PM   #15
1930artdeco
1930artdeco's Avatar
That is one really nice looking truck! As far as the wood goes, Maybe marine grade A which is sanded smooth on one side with no knots. That should withstand any sun/heat.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 07-11-2024, 08:22 PM   #16
Ken B
Ken B's Avatar
I thought about marine grade plywood but wonder if it is flexible enough to bend to the curvature of the body.
Old 07-12-2024, 05:19 AM   #17
ronn
you have very little curvature. boats far more...........
Old 07-12-2024, 06:19 AM   #18
rileyracing
rileyracing's Avatar
The depot hacks where I work part time are laminated/plywood, I think 1/4? It's not quite Luan thin, but definitely not thick either.
Really nice body so far. Looking forward to seeing the finished project!
v/r,
jason
Barnstormers VSC- Celeritate Est Vita
Battery Fabrication Technologist- Ford Motor Company
Antique Vehicle Mechanic- Greenfield Village
Sometimes Docent - Ford Piquette Avenue Plant
Member #347- Early Ford Registry
rileyracing on the HAMB
rileyracing is offline   Reply With Quote
Old 07-17-2024, 02:36 PM   #19
henry's 31
Wow, its looking great on a very rare vehicle. It will be something to see when it is finished.
Henry' s 31
henry's 31 is offline   Reply With Quote
Old 07-19-2024, 11:43 AM   #20
Russell Reay
Russell Reay's Avatar
Looking good. I think any 1/4" plywood will easily bend to the curvature of your lower body. Kudos for the front of your roof structure. I tried several ways to do the same thing on my huckster--I really like the visor. I could never determine how to make the transition from the wooden top which is about 2" wider than the A pillars. I defaulted to the wood overhang as most commonly done. It came out OK.
Russell Reay is offline   Reply With Quote
