Old 05-16-2024, 03:29 PM   #1
Pilotdave
Pilotdave's Avatar
Default Speedometer Cable Assembly Parts - Borg Warner Overdrive
I have a 1950's era Borg Warner overdrive (R10-B) in my SW Fordor. I'm looking for the bullet, shown in the attached photo, that connects the speedometer (square) cable/housing to the speedometer port on the overdrive unit. I'm also looking for the gear that connects the speedo cable to the drive gear inside the overdrive unit. I understand that the "standard" gear tooth count is 22, likely used for a 3.73 rear end. I have a high speed rear end so would likely need a lower tooth count to obtain accurate speedo readings.
So....any help with sources for these parts and advice on the needed gear tooth count would be greatly appreciated.
Pilotdave is offline   Reply With Quote
