Old 10-17-2012, 04:44 PM   #1
Chris
Chris's Avatar
Default Help ID this flathead Ford V8 "ELIMINATOR" camshaft
A buddy of mine dropped this by my work today, wants me to sell it for him...only I have no idea what it is. Kinnda weird. I think it is an 8BA as it has no slot up front for the distributor but has a bolt on front distributor drive gear. The front and center bearing surfaces have an oiling grove cut into them. and looks like it was done with a cut off wheel, and the rear oilng grove has had the ends blocked off by welding. I would assume for high oil pressure?
It appears to be a new billet, and has ELIMINATOR stamped into the snout. Can anyone ID this thing...or even better, got any specs?
Thee Inland Emperors
Chris is offline   Reply With Quote
Old 10-17-2012, 09:23 PM   #2
Tim Ayers
Default Re: Help ID this flathead Ford V8 "ELIMINATOR" camshaft
Chris:
I sent you a PM on this. This is an original Potvin Eliminator ground on a '32 cam.
Thanks.
Tim
Old 10-18-2012, 03:18 PM   #3
Kahuna
Kahuna's Avatar
Great Cam
Kahuna is offline   Reply With Quote
Old 10-18-2012, 07:20 PM   #4
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
Originally Posted by Tim Ayers View Post
Chris:
Thanks.
Tim
Tim, why do say it a 32 core? it has the gear on front for the 8BA dist. I don't know why someone blocked that groove in the rear journal, there is no oil pressure there there on that rear journal, the only way that rear bearing gets oil is what runs in from the back gears and there is no pressure back there. Walt
Old 10-18-2012, 07:24 PM   #5
Walt Dupont--Me.
Sorry Tim, I read the first post again and see that it has a bolt on front dist gear. Walt
Old 10-18-2012, 07:33 PM   #6
Ol' Ron
Ol' Ron's Avatar
These were modified this way by boring out the front and pressing in a plug then turning it down for the 8BA front distributoe, I've done several. Same with the bolt on gear, but I've never done that.
Old 10-18-2012, 07:54 PM   #7
Tim Ayers
No problem. I was looking at '32 cam at Hershey a few days ago, had the same tell tale "oil grooves" in the journals.
Also, the machining marks in the snout.
Old 10-18-2012, 09:54 PM   #8
bluardun
bluardun's Avatar
The post just below inquires about .010 stamped on the remanf. tag three time. I notice this cam is stamped with .010.
Could this be the area where the cam bearing ride was cut .010. because it is a '32 cam?
Most of the '32 motors didn't have cam "bearings as the later engines.
Interesting ????????
bluardun is offline   Reply With Quote
Old 10-19-2012, 05:48 AM   #9
JWL
Yes, the journal diameters are probably .010 undersize and will require the appropriate cam bearings. The rear oil groove is blocked off when the rear cam bearing has been pressurized which will cause oil to spray out on the crankshaft and rob mucho power.
JWL is offline   Reply With Quote
Old 10-19-2012, 02:03 PM   #10
Pete
From the pics it appears to be an original Potvin Eliminator.
The stamping on the nose is as the originals appeared.
I have reground many over the years and they have a distinctive look to the machining style also.
It definetly needs to be reground to be usable and the rust pits on the journals could be a problem if it needs to be more undersize. This would require home made bearings.
The specs are:
Model425
Intake 26-74
Exhaust74-26
Lift .410
Advertised duration 280
Lobe seperation 112
Rate of lift .008
Old 02-27-2014, 01:11 PM   #11
Atwater Mike
That's a Potvin Eliminator, all right. When Chuck Potvin moved his equipment into Dean Moon's shop, I called him for a Potvin Eliminator for my 304" flathead. (1983?)
Dean said they could supply me with that cam, BUT!
Unless I had a 1932 Ford V8 cam core, there would be a monsterous core charge...('32 V8 cams were steel, not cast... Chuck Potvin only cut the eliminators from steel cam cores)
I found one eventually, Brian Burnett had it. This stick had more 'snap' than any others I ever used...like witchcraft!
Atwater Mike is offline   Reply With Quote
Old 02-27-2014, 06:48 PM   #12
KiWinUS
KiWinUS's Avatar
So chuck machined the front of the press on cam gear snout to be a bolt on also ?
I have one just like this .
Old 04-27-2024, 04:06 PM   #13
panic
I've written an Excel spreadsheet containing the data for the Potvin 3/8 and another for the Potvin Eliminator. This includes how the events are calculated and some comments bout each.
PM me for a free copy.
panic is offline   Reply With Quote
