Old 06-13-2023, 07:00 PM   #1
datacompal
Default 1929 Model A rear wheels
I have been helping a relative work on his collection of Model As
and I have run into something I don't know about.
When the car is going sown the road, the rear wheels wobble. I have
already checked and made sure the rims aren't bent and that the lug nuts
are tight.
Is this a major repair or something simple that can be taken care on the car?
datacompal is offline   Reply With Quote
Old 06-13-2023, 07:29 PM   #2
Keith True
Keith True's Avatar
Default Re: 1929 Model A rear wheels
Sounds like when the rear hubs/drums were put on the key rode up a little bit in the axle while sliding them on.I would check for that first before looking for bent or warped parts.
Keith True is online now   Reply With Quote
Old 06-13-2023, 08:20 PM   #3
Ivan in southeast va.
Ivan in southeast va.'s Avatar
Make sure that the rear axle nuts are torqued to approximately 100 ft.lbs
Ivan in southeast va. is offline   Reply With Quote
Old 06-15-2023, 06:04 PM   #4
ModelA29
ModelA29's Avatar
Have you switched the wheels on that car? I couldn't find it again but I think that some wheels didn't sit tight on the drum allowing them to flex/warp when tightened down.
ModelA29 is offline   Reply With Quote
Old 06-15-2023, 06:46 PM   #5
datacompal
Thank you for all the responses. Gives me a starting point to
look at before tearing the car apart.
Old 06-15-2023, 11:02 PM   #6
Y-Blockhead
Y-Blockhead's Avatar
Only if he has very early '28 wheels on a later car would that become a problem.
Old 06-16-2023, 08:28 PM   #7
ModelA29
ModelA29's Avatar
I knew there could be a problem but wasn't sure why. He mentioned his friend had a "collection" of Model As so I thought maybe they could have swapped some wheels around.
