Old 04-08-2023, 06:42 AM   #1
Easy
Default Radial tire pressure
What is the recommended pressure to run in the 19 inch American Classic radials?
Easy is offline   Reply With Quote
Old 04-08-2023, 07:04 AM   #2
nkaminar
nkaminar's Avatar
Default Re: Radial tire pressure
The tires have 35 psi printed on them. I found this to be too low. I run 50 in the rear and 45 in front with my heavy Fordor. Go for a drive of about 10 miles then touch the sidewalls. It they are hot to the touch then the pressure is too low. The sidewalls should be warm, but not hot. Disclaimer: Since the tires have 35 psi printed on them, you are on your own when increasing the pressure. Modern tires that are not damaged, for instance by running on them when they are flat, can withstand 200 psi. But I am telling you what I do and not recommending that you do the same.
Old 04-08-2023, 08:06 AM   #3
old31
Coker told me to run 35 psi on my 19" ww radials.
old31 is offline   Reply With Quote
Old 04-08-2023, 09:54 AM   #4
Y-Blockhead
Y-Blockhead's Avatar
I tried 40psi in my 4.50-500x19 American Classic radials and found the ride a little on the harsh side. Drop down to 35psi and the ride is much more to my liking.
I suggest you try different pressures on your car and find what you like.
Old 04-08-2023, 10:07 AM   #5
alexiskai
alexiskai's Avatar
I’m guessing the different answers have a lot to do with the different weights of these cars. Neil’s car is pretty heavy as I recall.
Old 04-08-2023, 10:19 AM   #6
Y-Blockhead
I can't imagine his car being that much heavier than my '30 Town Sedan.
Old 04-08-2023, 12:07 PM   #7
Big hammer
IMHO by over inflating your radial tires, you’ve turned them into bias ply tires
get a bigger hammer tap done
Big hammer is online now   Reply With Quote
Old 04-08-2023, 02:07 PM   #8
CarlG
CarlG's Avatar
My Coker 19" radials say on the sidewalls: Max 44 psi. I run mine at 40 psi, works for me.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 04-08-2023, 02:57 PM   #9
alexiskai
alexiskai's Avatar
If you run the car’s weight and the tire load rating through tire pressure calculators, usually you come out with 25-35 psi as the recommended pressure, depending on the body type and expected passenger weight. I did this for the American Classic 21” radials.
Old 04-08-2023, 05:02 PM   #10
jadatis
Tirepressure is all about load on tire, and maximum speed used.
All not to overheat any prt of tire-material, when driving the speed constantely.
So if you give tire specifications, this "pigheaded Dutch selfdeclared tirepressure specialist" will make a pressure/axleloadcapacity list, with build in reserve.
Then you only need to determine the axleloads acurately and s3arch them back in my list, the most tricky part, and your responcibility.
Need next.
1. Maximum load or loadindex.
2. Kind of tire to determine the maxloadpressure.
3. Speedcode, less important.
jadatis is offline   Reply With Quote
Old 04-08-2023, 07:07 PM   #11
nkaminar
nkaminar's Avatar
My Fordor has a heavy metal trunk in the back loaded down with heavy tools and parts. Another heavy tool box in front with oil, coolant, and more parts. Plus all the added body insulation and tools under the seats. Did I mention there are lots of tools. With the tire pressure I run the radials still perform like radials.
Again, it comes down to heat. High temperatures can limit the life of a tire and ruin the inner tube. Too much flexing leads to too much heat.
Old 04-09-2023, 09:50 PM   #12
Model A Ron
Model A Ron's Avatar
I just got a set on this weekend and filled them to 35. I have not went for a test drive yet but the tires look underinflated at 35. I will see if they get hot after a 10 mile ride and I have a feeling they will......next will be increase to 45. I tend to run my modern cars at max psi.....tires last longer and better MPG. You do get a harder ride but I will take that for more tire life.
Model A Ron is offline   Reply With Quote
Old 04-10-2023, 08:13 AM   #13
TerryO
TerryO's Avatar
I run 35 lbs and they drive very well...
TOB
TerryO is offline   Reply With Quote
Old 04-10-2023, 11:16 AM   #14
goldie
If you remember back in the olden day when radial tires first came to use in the USA they all bulged. They appeared to be low on air pressure but were not. My new American Classic radials set at the max of 35 psi also have that bulging look where the rubber meets the pavement. Have to believe modern radials have stiffer sidewalls, but not the American Classics.
goldie is offline   Reply With Quote
