Old 03-06-2022, 07:40 AM   #1
graeme_capon
Default 1935 Ford Diff Ratio Advice
Hi,
Can someone give me some advice on working out Diff ratio, my current setup is way too low geared so im rebuilding the diff with a new crown and pinion gear set (I dont know the current diff ratio)
Some details below :
In have 1935 ford coupe ,currently building a new flathead engine for the car which will be a stroker engine 59a block
Running a 1939 Ford 3 speed
Running the standard Banjo diff
Wheel size is 15" with a set of Coker 560-15
Can someone advise of a good ratio for this setup or how to calculate what ratio is needed.
Thanks
graeme_capon is offline   Reply With Quote
Old 03-06-2022, 07:44 AM   #2
graeme_capon
Default Re: 1935 Ford Diff Ratio Advice
The car I require advice on.
Thanks
Old 03-06-2022, 07:53 AM   #3
corvette8n
corvette8n's Avatar
Welcome, great looking ‘35, does it have a rumble seat?.
See this link about ratios
http://www.advanced-ev.com/Calculators/TireSize/
Old 03-06-2022, 08:11 AM   #4
mfirth
graeme, sorry I can't help with the ratio, but I sure love your car.. Very Nice !!! Welcome to "The Barn !!
mfirth is offline   Reply With Quote
Old 03-06-2022, 09:08 AM   #5
PeterC
PeterC's Avatar
My view of ideal for your Coupe s a Columbia 2 speed with a 4:11 - best of both worlds in one rear!
PeterC is offline   Reply With Quote
Old 03-06-2022, 09:40 AM   #6
Ford Freak
I put 3:54's in my '37 w/ 27" diameter rear tires. My engine is a stock 1940 85 hp.
This ratio is much better than the 4:11's that were in it! I can now cruise @ 60 mph turning 2600 rpm. 65 mph is about 2800 rpm, but it's "sweet spot" is 60 mph. This car has a 9" clutch & the moderate hills in my area are no problem from a dead stop. - F F
1952 Ford F1
!956 Fairlane Club Sedan
1965 Falcon Sprint
2007 Mustang GT
Ford Freak is offline   Reply With Quote
Old 03-06-2022, 09:59 AM   #7
Kube
Kube's Avatar
I have a 4:11 in my stock '36 roadster with a correct (36) Columbia. The car will do 60 - 65 without effort. Very happy car at those speeds.
If you don't want the suffer the expense of a Columbia, I'd suggest a 3:78. That's what is in my '39s and '40s - all stock cars. Very nice ratio for all types of driving.
Old 03-06-2022, 10:46 AM   #8
tubman
tubman's Avatar
Aren't 5.60-15 tires a little small (especially in the rear)? That's the size that came on Volkswagen Beetles.
Old 03-06-2022, 12:33 PM   #9
19Fordy
19Fordy's Avatar
Yes, 5:60 x15 tires are only 25.88 inches in outside dia.
Consider changing to a larger size tire. For instance:
https://www.summitracing.com/parts/C...RoCy_UQAvD_BwE
Old 03-06-2022, 06:48 PM   #10
Detonator
Detonator's Avatar
If want to stick with the 5.60-15's, I'd go with a 3.54 ring and pinion.
Seabright Hot Rods
Detonator is offline   Reply With Quote
Old 03-06-2022, 07:05 PM   #11
petehoovie
petehoovie's Avatar
Thanks
