So friends have come to the conclusion that the solenoid is trash. When out on the bench and 6V power is applied to it the plunger just oscillates in and out. I an told it should snap in and stay there, so at this point I am going to send it to Tom Endy, if he will have it. Anyone near Danville, Ca selling one?
Thanks to all who helped. |
Enlighten us as to what sol you're speaking of or send us to the original post please.
Paul in CT |
Did you use a good battery and heavy wire to test the solenoid? It take quite a bit
of current to pull the solenoid in then the holding windings take over. Have you seen the BW manual Tom Endy posted? http://www.santaanitaas.org/wp-conte...ner-manual.pdf |
Dave, Is this for a Borg-Warner overdrive?
okay important question Davey! Who nicknamed you Ace Mechanic?
Snoopy in France, 1917, over a fag and coffee as I repaired his Sopworth Camel, shot up by the Red Baron.
I am no BW expert but is it possible that the solenoid is 12 volts not 6?
