Old 04-22-2021, 11:31 AM   #1
jdpaxton
Default 46 ford rear drum cutting
Is it possible to cut the drum and hub together rather than removing the drum from the hub. I checked one shop with a brake lathe and he didn`t have anyway to center up the hub. The drums I have use studs pressed in from the back side. Hub has the round plate.
jdpaxton is offline   Reply With Quote
Old 04-22-2021, 12:41 PM   #2
JSeery
JSeery's Avatar
Default Re: 46 ford rear drum cutting
If you can find someone that has the correct equipment. Because these type of drum/hubs have not been around much sense the 40s - 50s, it will be hard to locate one.
Old 04-22-2021, 12:46 PM   #3
V8COOPMAN
V8COOPMAN's Avatar
You always turn those drums as a drum/hub UNIT....DO NOT separate! Now, most shops today do not have the arbor required to hold that hub. Many times, shops that do VW drums have the needed tool. Look around for an old shop, especially with old guys doin' the wrenching. They are STILL out there. You might even try shops that do big trucks. Whatever you do, do NOT let someone talk you into separating the drum and hub. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 04-22-2021, 01:03 PM   #4
jdpaxton
I will do a search and see if anyone recalls the adapter. Thanks
Old 04-22-2021, 01:05 PM   #5
Kurt in NJ
Kurt in NJ's Avatar
The Barrett brake lathe has adapters that fit in the wheel bearing without removing the seal, and a small cone for the outer
Old 04-22-2021, 01:06 PM   #6
Tim Ayers
X2. Look for the older gentleman with grease stained overalls at the oldest machine shop in your area. Tell him what you got. He'll either know right away or tell you he got rid of that brake lathe arbor years ago.
Most machinist don't throw away anything, so your chances are good.
Old 04-22-2021, 02:56 PM   #7
Ggmac
I have cut mine on the lathe using a old axle . Not easy or fast but it worked .
Old 04-22-2021, 03:00 PM   #8
19Fordy
19Fordy's Avatar
Is there anyway the hub could be "chucked up" in a big lathe and slowly "turned"?
Old 04-22-2021, 03:01 PM   #9
alanwoodieman
use a stub axle and cut on lathe. old brake drum machines had a very small arbor to do this combo and not too many of them around
Old 04-22-2021, 04:27 PM   #10
V8COOPMAN
V8COOPMAN's Avatar
Depending on what brand of brake lathe the shop has, the arbor for Ford rear hubs may look something like this set-up. It's that small (11/16") outer opening in the hub that is hard to match today. DD
T5 W/TORQUE TUBE
Old 04-22-2021, 04:48 PM   #11
Charlie Stephens
They have to be turned together. Unless you are in the witness protection program add your general location to your profile and maybe someone will suggest a place near to you that can do the work.
Charlie Stephens
Old 04-22-2021, 05:00 PM   #12
Charlie ny
Pax,
If you are reasonably near me I can turn them....1953 AMMCO lathe and Ford
Arbor.
Charlie ny
near Buffalo
Old 04-22-2021, 05:45 PM   #13
motordr
Pax, don’t know where you are located but I can turn them if you are in Ontario Canada.
Ted
motordr is offline   Reply With Quote
Old 04-22-2021, 07:03 PM   #14
rich b
rich b's Avatar
If the place has an Ammco brake lathe; they may have the small OD arbor laying on a shelf and not know that is what they need for rear drums.
Here is a picture of the regular and small OD arbors.
Old 04-22-2021, 08:08 PM   #15
V8COOPMAN
V8COOPMAN's Avatar
Originally Posted by Charlie ny View Post
Pax,
Arbor.
Charlie ny
near Buffalo
Ted
This is just one REALLY good reason for EVERYONE to make sure your approximate location is noted below your screen names, particularly all you's NEW guys. Just sayin'! DD
T5 W/TORQUE TUBE
Old 04-22-2021, 09:09 PM   #16
csmbraz
As others have stated, don't know your location....but, I'm located in central North Carolina, and I have the equipment needed to turn your drums...
csmbraz is offline   Reply With Quote
Old 04-22-2021, 10:03 PM   #17
19Fordy
19Fordy's Avatar
It is truly wonderful that several Fordbarners have offered to turn your drums.
Well done folks.
Old 04-22-2021, 10:11 PM   #18
cas3
Agree ^^^ amazing we have that many brake lathes amongst us !
Old 04-22-2021, 10:49 PM   #19
V8COOPMAN
V8COOPMAN's Avatar
And, there are likely a few more. But the REAL question....HOW MANY folks do we have that are equipped and willing to ARC brake shoes? DD
T5 W/TORQUE TUBE
Old 04-23-2021, 03:03 AM   #20
Kurt in NJ
Kurt in NJ's Avatar
on the top of the drum doktor are the rear drum adapters, one that fits in the wheel bearing, and the small cone for the outside. ---a drum doktor cuts different than most brake lathes instead of a steady feed that makes a spiral cut it cuts a full turn then moves over with a ratchet mechanism
For arcing shoes with fixed anchors the barrett brake doktor arcs and centers the shoes on the backing plate.
For full floating like bendix the aamco arcing machine works better , though the brake doktor has adapters to do bendix too
