Old 12-13-2020, 05:03 PM   #1
Chuck Dempsey
Chuck Dempsey's Avatar
Default headlight current tied to ignition switch?
Is there any SIMPLE way to run the headlights ONLY when the ignition switch is ON? I say SIMPLE because my electrical skills suck.
Thanks
Chuck Dempsey is offline   Reply With Quote
Old 12-13-2020, 05:10 PM   #2
Bill G
Bill G's Avatar
Default Re: headlight current tied to ignition switch?
Thanks
No, no simple way, especially if your electrical skills suck.
Can it be done? yes.
Old 12-13-2020, 05:15 PM   #3
Kurt in NJ
Kurt in NJ's Avatar
Hook the ignition to the headlights
Old 12-13-2020, 05:26 PM   #4
Patrick L.
Patrick L.'s Avatar
Sure it can be done, but, not too easily. Its much easier to make sure the light switch is at 6:00 and look at the ammeter.
Part of my post-flight mental checklist is to lastly glance at the ammeter.
Old 12-13-2020, 07:14 PM   #5
Ranchero50
If your electrical skills suck, probably no...
That Henry chose to put the ignition switch on the wrong side of the coil (points versus source) it's even more of a pain.
Building a '29 Speedster, the hard way...
Ranchero50 is offline   Reply With Quote
Old 12-13-2020, 07:16 PM   #6
Bob C
Not sure what you are trying to do since the ignition switch has nothing to do with the head lights. Are you wanting the headlights only, not tail lights, to turn on when you turn the key on?
Old 12-13-2020, 07:57 PM   #7
Chuck Dempsey
Bob, I just want to stop leaving the headlights on when I shut off the engine after a drive. I'm getting better at checking the headlight switch, but if I could easily arrange a cutoff of the headlight via the ignition, I'd set it up.....
Thanks all for the input!
Old 12-13-2020, 08:20 PM   #8
Mister Moose
Mister Moose's Avatar
Sounds like a job for a 20A rated relay that would close with 6V. If that sentence scares you then it's not easy enough. Or find a friend.
Mister Moose is offline   Reply With Quote
Old 12-13-2020, 08:25 PM   #9
GRutter
GRutter's Avatar
If using an original pop-out ignition switch, then NO.
If using a simple off-on ignition switch, it "could" be done, but would require re-wiring the ignition circuit.
A concern that I would have is the wire gauge and current you would be running through the ignition switch.
With original wiring, the ignition switch only sees about 4 amps. Re-wired to support running lights plus ignition, it could see 15+ amps.
GRutter is offline   Reply With Quote
Old 12-13-2020, 08:28 PM   #10
J Franklin
J Franklin's Avatar
Your best bet is to just look at the switch when turning the car off. Post a note on the dash till you get into the habit.
Old 12-13-2020, 08:55 PM   #11
shew01
shew01's Avatar
Would something like this help?
https://www.napaonline.com/en/p/GRO8...SABEgJPU_D_BwE
It’s not a bad idea to shut off all the current on 90 year old wiring when you aren’t using the car anyway.
Old 12-13-2020, 09:19 PM   #12
Jacksonlll
Jacksonlll's Avatar
I had this problem and I put in a buzzer that will let me know when the lights are on and my door is open. Been workin good for a long time.
Here is the video.
https://youtu.be/it7C06vanBs
Old 12-13-2020, 09:35 PM   #13
Ian in Mississauga
I hooked up my dash light to the wire going to the tail light. Now if the parking lights or headlights are still on when I turn the key off I got a visual reminder. No goofs since I did this.
Ian in Mississauga is offline   Reply With Quote
Old 12-14-2020, 05:41 AM   #14
Bruce of MN
Bruce of MN's Avatar
Did you put a diode in the line? Otherwise, that might light your tail lights any time the dash light is on.
Old 12-14-2020, 06:49 AM   #15
Chuck Dempsey
Lots of good ideas. The tail light-dash light idea sounds about my level...
Thanks all.
Old 12-14-2020, 07:41 AM   #16
bbrocksr
Thanks all.
Use a battery cut off switch like post 11 says, shuts off all the power when turned off.
Bill
bbrocksr is offline   Reply With Quote
Old 12-14-2020, 08:56 AM   #17
TJMack
Talking Re: headlight current tied to ignition switch?
I love your sense of humor. :-)
TJMack is offline   Reply With Quote
Old 12-14-2020, 09:19 AM   #18
MickeyT
Send a message via MSN to MickeyT Send a message via Yahoo to MickeyT
I use the electrical cut-out mentioned above. Then in case I forget that I've got in the habit of tapping the horn button when I get out of the vehicle.
MickeyT is offline   Reply With Quote
Old 12-14-2020, 09:30 AM   #19
Curtis in MA
Where did you put the battery cut-out switch?
I don't like drilling metal and on the wood floor I'd kick it.
Curtis in MA is offline   Reply With Quote
Old 12-14-2020, 10:59 AM   #20
Chuck Dempsey
Ditto on Curtis' question. Where? I've got a Tudor, so under the driver seat floorboard might make sense.....
