Old 05-28-2018, 09:03 AM   #1
russcc
Default Aftermarket part #s steering parts
Anyone have a list of aftermarket parts for '37-56 Ford steering box;
B-3552 upper race/cup, Timken #6 or ?
48-3591 sector seal, CR-11067 or ?
78-3576-A Bushings or ?
Thank you Fordbarners.
Old 05-28-2018, 03:14 PM   #2
1948F-1Pickup
1948F-1Pickup's Avatar
Default Re: Aftermarket part #s steering parts
Assuming the Timken #6 is a SET6,
you'd be looking at LM67048 and LM67010 in NTN/Bower.
The first number is the cone or rolling element and the second number is the cup or race.
In SKF's product line this is a BR6 or an A-6 would be the Federal Mogul/Moog ID.
The seal numbers are IN GENERAL industry trade numbers. CR, unfortunately marches to their own drum-beat. A CR 11067 shows as a 352560 in Federal Mogul/National & SKF. That same CR # also lists as 50161S in FM/National and SKF.
NTN/Bower/BCA doesn't offer any cross-reference for the CR 11067.
Can't help on the bushings. The corporation I work for only makes bearings......
1948F-1Pickup is offline   Reply With Quote
Old 05-28-2018, 03:50 PM   #3
Ken/Alabama
Ken/Alabama's Avatar
Upper race - Timken 6
Lower Race - Timken 6CE
Bearings - Timken 5BC
Old 08-13-2020, 10:30 PM   #4
Ron Pilger
Ron Pilger's Avatar
Looking for the 48-3591 steering gear oil seal for the 37 box. I’m not clear if if the CR or Federal- Mogul seals as described in the 2 year old post above are exact replacements. Can anyone confirm? Thanks in advance.
Ron Pilger is offline   Reply With Quote
Old 08-14-2020, 06:27 PM   #5
1948F-1Pickup
I completely went through the box in my '48 not long ago.
Although not an exhaustive list of everything, here are the
part numbers.....
- 7HC-3524 NOS steering shaft & worm
- 7RC-3575 NOS sector shaft
- Lower bearing race 8A 3553 Timken 6CE
- Lower bearing cone 68 3571-A Timken 5BC
- Upper bearing race B 3552 Timken 6
- Upper bearing cone 68 3571-A Timken 5BC
- Sector shaft bushings NOS 78-3576-A
- Sector shaft seal Timken 240151
I don't have a cross reference that shows Timken's 240151 as being correct
for 48-3591 but if a '37 box is the same as a '48.......
Old 08-14-2020, 10:40 PM   #6
Ron Pilger
Ron Pilger's Avatar
Thank you, 1948F-1Pickup. Very helpful info for me. Ron
