Old 04-23-2020, 05:52 PM   #1
Steve Plucker
Default A-2853 Emergency Brake Lever to crossshaft Rod assembly
Is the Emergency Brake Lever to Cross Shaft Rod Assembly, A-2853, on the Mid 1928-Mid 1929 vehicles with Emergency Brake Lever in front of the gear shift and where it attaches to the Emergency Brake Cross Shaft Rod Assembly, slightly bent to the right or left depending on which way you look at it if it was installed? OR is it a perty much stright rod?
Thanks.
Pluck
Old 04-23-2020, 06:59 PM   #2
kbinde2
kbinde2's Avatar
Default Re: A-2853 Emergency Brake Lever to crossshaft Rod assembly
'29 Special Coupe for my example Pluck, May 1929 for production time-frame.
The rod that you reference is straight. E Brake handle is in front of the shifter..
kb
kbinde2 is offline   Reply With Quote
Old 04-23-2020, 11:14 PM   #3
Steve Plucker
Thank you kb...guess I will have to strighten mine.
Pluck
