Old 08-17-2018, 07:36 AM   #1
corvette8n
corvette8n's Avatar
Default How to almost burn up your ride.
1. Be in a hurry(wanted an Ahooga horn installed in time for a car show).
2. Mount the horn relay on the backside of the bracket.
3. Park car near a wall so you have to lean way over the hood to reach the horn.
4. Don't have enough light.
5. Wire everything by feel cause you can't see the markings on the relay.
6. Sit on passenger side to test(remember you parked too close to the wall and can't open drivers door).
7. Turn on master disconnect under dash(glad I installed it).
8. Lean over to drivers side to press auxiliary horn button.
9. Nothing happens but notice smoke coming from under hood.
10. Panic (where's that cutoff located, didn't I just turn it on?)
11. Watch smoke billow up from under hood, find switch and turn it off.
12. Remove burned up relay and wiring, check to make sure all the original wiring is ok.
13. Put project off until another day.
Old 08-17-2018, 07:43 AM   #2
JWL
Default Re: How to almost burn up your ride.
I understand!!
JWL is offline   Reply With Quote
Old 08-17-2018, 07:55 AM   #3
51504bat
51504bat's Avatar
Once you let the smoke out you can never get it back in! Glad it wasn't any worse than it was.
Old 08-17-2018, 08:23 AM   #4
JSeery
JSeery's Avatar
Funny story, at least no real damage. I learned wiring the hard way in my youth and have the scars to show for it!
Old 08-17-2018, 08:53 AM   #5
34pickup
34pickup's Avatar
Well, at least you didn't wire an amp gauge with a lamp cord like I did a a young buck on my first car decades ago. Started burning at a stop light. Lucky I was also too lazy to tighten the battery cable so it came off quickly. We are capable of huge relapses in judgement.
Matt 24:36-41
34pickup is offline   Reply With Quote
Old 08-17-2018, 08:54 AM   #6
uncle buck
uncle buck's Avatar
Lucky you. I think we've all had an oops before from being in a hurry.
uncle buck is offline   Reply With Quote
Old 08-17-2018, 04:56 PM   #7
A bones
A bones's Avatar
Thanks for the master switch reference. Safety is a beautiful thing.
Enjoy yer day. Tom
Hate can't fix what it started.
A bones is offline   Reply With Quote
Old 08-17-2018, 05:02 PM   #8
Ggmac
If I may add . ALWAYS disconnect battery ( or shut off ) when parking cars in the garage .
Old 08-17-2018, 07:21 PM   #9
Tinker
Tinker's Avatar
Electricity does not compromise, it does what it does
Glad you were able to cut power fast.
Old 08-17-2018, 08:52 PM   #10
jim1932
jim1932's Avatar
These cars are so simple. There are tobs of simple trouble shooting info. I still jump to step 6 struggle for days then curse when step 3 was the issue....
Short URL: http://smu.gs/14g7eDW
jim1932 is offline   Reply With Quote
Old 08-19-2018, 09:45 AM   #11
32phil
First rule above all rules....
Always check what the previous owner did....
especially in the electrical dept.....if you don't.....
you may become close with your fire extinguisher and may create a very close call with the local Sunoco station..
Also check the brake dept....and last but not least the steering dept.
Ask me how I know …..
Early Ford Lock & Key Service
https://www.fordbarn.com/forum/showthread.php?t=46583
32phil is offline   Reply With Quote
Old 08-19-2018, 09:51 AM   #12
RalphM
RalphM's Avatar
Similar situation, a friend was replacing the headlight switch on his antique car. Did not disconnect the battery and almost caught the entire car on fire!
RalphM is offline   Reply With Quote
Old 08-19-2018, 11:07 AM   #13
Clem Clement
Clem Clement's Avatar
I wired an extra horn on my 41 opera coupe. driving along the boards in Cape May I tooted at some chick. The hot wire hanging beneath the dash went red hot. I grabbed the red were and pulled it loose. sizzled 4 fingers and the chick she never mind...
Old 08-19-2018, 06:42 PM   #14
russcc
Plenty of light when you do anything, and don't forget your glasses. The battery switch is wisest invest you can make in your car.
